welwynnick
- Joined
- Dec 26, 2023
- Messages
- 1,572
- Likes
- 1,985
I was just about to suggest that!And without MUTEC at all !
In the second tranche of tests with the RME in the chain, do you have any DSP running?
YesI was just about to suggest that!
Thanks for that - fascinating. I would have expected better from the RME.Did the Measurings, and i got suprised, look here:
https://www.diyaudio.com/community/...ound-digital-aktive-setup.440807/post-8412475
RME Card can't remove Jitter at all!!! Where is the StadyclockFS ????
Need to talk to RME i guess, need Answers, may be i am doing something wrong or need to setup different .....
Jep, MUTEC do the Jitter reduction Job much better than RME Card!Thanks for that - fascinating. I would have expected better from the RME.
The system works well with the Mutec before the RME, so the RME doesn't add jitter, but it doesn't reduce it with PLL etc.
You're quite right, it was a typo, I meant to type ES9039. I've actually got that datasheet open right now.No it uses the newer S3039Q2M Chip, not sure about SRC capabilitys changed.
That why i try to get my SETUP cheep as possible done and after it works like it should i starting changing Amps or DAC'S to wory about Sound but for me the most importand Point is to have the ability to use FIR Filter on all my Speaker i build or use on my 7.2 Setup!I thought I'd read the DIYA thread rather than ask obvious questions about what hardware, software and configuration you were using for the DSP.
I didn't realise you were using a PC, but now I know, I guess that opens every opportunity imaginable for DSP.
I understand what you're trying to do right now, but here's one to think about in the future.
PC's can do reconstruction filtering much better than any DAC. These links show what can be achieved with uncompromised filters:
Headphone Reviews and Discussion - Head-Fi.org
www.head-fi.org
We have a similar approach to audio, and I think you might find this thread interesting. It starts talking about AV processors with digital outputs, but goes on to discuss the possibilities for optimising each and every stage of the of the audio reproduction process, which is only possible with digital decoder outputs:
