- Joined
- Jul 12, 2024
- Messages
- 3,845
- Likes
- 6,055
Amrim turned that off. Some people are grandfathered.Other people have links in their signature, but I can't insert a link in mine, nor could I copy and paste the code from this post into my sig.
Excellent. Perhaps the Nuprime is ready for prime time after all.The latest firmware of the H16 seems to have fixed my primary gripe / QoL issue regarding settings getting lost after reboots.
Wanted to look into something that gives me the ability of a matrix mixer. So that I can do some manual routing or some upmix ability. AES in/out. I dont have space for an RME pcie card.Anything you're looking for in particular?
I didn't collect that sort of information in the spreadsheet, but I did look at that functionality.Wanted to look into something that gives me the ability of a matrix mixer. So that I can do some manual routing or some upmix ability. AES in/out. I dont have space for an RME pcie card.
The legacy Yamaha units that accept mini-YGDAI expansion card slotsWanted to look into something that gives me the ability of a matrix mixer. So that I can do some manual routing or some upmix ability. AES in/out. I dont have space for an RME pcie card.
For now just that, though dsp is a bonus. I am still tempted to just got for a trinnov ci, but then the cost of that is much higher than even interfaces like the grace design m908Is it just matrix switching you need, or some DSP functions as well?
??? no space for an RME Card but for an grace design m908 or trinnov ci ???Wanted to look into something that gives me the ability of a matrix mixer. So that I can do some manual routing or some upmix ability. AES in/out. I dont have space for an RME pcie card.
I think I'm going back to analog. Shits over my head.One interesting wiring challenge for these interfaces will be how to deal with AES IO if I want this device between the H16 that outputs via 2x db25 and the genelec 9301b that takes input via same 2x db25.
H16 outputs 16 channels (8x AES pairs) over 2 DB25. 4 on the 1st AES and 4 on the 2nd. Obviously it has no inputs, so the DB25 connector for the input channels is dead/unused/not connected.
Now if that needs to connect to an interface, and let's take rme hdpse as an example, it will need a special db25 cable. 1st db25 from h16 goes into the 1st AES input of the rme card. 2nd db25 goes into the 2nd rme AES slot. But now I have to take output from the same db25 out from the rme and send it to the genelec. So will need a special db25 cable whose connector at the interface takes in input from h16 but takes output from rme to genelec.
Alternative is obviously take multiple breakout db25 to xlr snakes or breakout box and connect that way, so more of a wire mess or yet another box on the shelf.
Yes, iwas also looking in this Thunderbold Enclosures but they all works with Thunderbold , for MAC user great but with an RPI5 i am not sure how good it would work.Something like these also may work
They even list rme. And can use with macs too.![]()
Echo SE I T5 (1 PCIe slot + space for a daughter card • Thunderbolt 5)
Compact Thunderbolt 5 PCIe expansion system with one PCIe slot plus space for a daughter card. Supports audio, video, fibre, RAID, and Ethernet PCIe cards.www.sonnetstore.com
I don't think the RME Card would work with such an USB to PCIE Adapter on an RPI5 but not sure never used one.There are many plain USB to PCIe adapters and enclosures that allow RPi5 to use standard PCIe cards, and most are cheaper than that.
Thunderbolt is supposed to be backward compatible but TB just adds costs if you host is USB2 / USB3 only.
Also Sanctuary Systems "Sentinel Core" should ship soon, hosts CM5 instead of RPi.
Of course the PCIe card you want to use must work with Linux.
You can only do PCI-e pass through with USB4, the rPI5 only has USB3 the only way to get PCI-E on an rPI5 is via the M2 Hat and an M2 format interface.There are many plain USB to PCIe adapters and enclosures that allow RPi5 to use standard PCIe cards, and most are cheaper than that.
USB conversion is just one path.You can only do PCI-e pass through with USB4, the rPI5 only has USB3 the only way to get PCI-E on an rPI5 is via the M2 Hat and an M2 format interface.
