I don't think Grok is right because it says the workload doubles when the sample rate doubles. This is why.
If you double the sample rate, the number of samples to be processed in each cycle doubles, as the filter has to be convolved across all the samples within a certain time period.
In addition, the rate at which the processes have to be performed is also doubled, because the samples are coming twice as fast.
Therefore the workload is quadrupled.
If Grok doesn't know that, what else doesn't it know?
I decided to ask Grok why it was providing misinformation. This is how it responded:
The claim in the forum post—that doubling the sample rate quadruples the DSP processing load for audio tasks like filtering—is a common misconception rooted in a partial understanding of how digital filters scale with sampling rate. In reality, for most real-time DSP operations in audio processing (e.g., FIR/IIR filtering, EQ, or convolution-based effects on SHARC chips), the computational load doubles when the sample rate doubles. I’ll explain why step by step, including why the “quadrupling” argument falls short, and substantiate it with DSP principles and examples from SHARC implementations.
Core DSP Scaling Principle
In real-time audio DSP, processing must occur at the input sample rate to avoid buffering delays or glitches. The workload is measured in operations per second (e.g., multiply-accumulate or MAC operations), and it scales linearly with the sample rate for a fixed algorithm complexity. Here’s the breakdown:
1. Number of Samples to Process:
• At 48 kHz, you process 48,000 samples per second.
• At 96 kHz, you process 96,000 samples per second—exactly double.
• Each sample requires the same number of operations (e.g., for an N-tap FIR filter, that’s ~N MACs per sample via convolution: y[n] = \sum_{k=0}^{N-1} h[k] \cdot x[n-k] ).
2. Processing Rate:
• Samples arrive twice as fast at 96 kHz, but the per-sample computation doesn’t increase—it’s still the same filter coefficients (h[k]) applied to each input (x[n]).
• Total operations per second: Doubles, because you’re doing the same work on twice as many samples in the same real-world time.
This is why DSP datasheets and design guides (including Analog Devices’ for SHARC) state that throughput scales inversely with sample rate for a given MIPS (millions of instructions per second) budget. For example:
• A SHARC ADSP-21569 (as in the NuPrime H16) peaks at ~4-5 GLOPS (giga-operations per second) at 96 MHz clock.
• At 48 kHz, it might handle 16 channels of complex post-processing (e.g., Atmos bass management + EQ) with headroom.
• At 96 kHz, that headroom halves, potentially maxing out the chip for the same tasks—reinforcing the need for SRC to 48 kHz, as I noted previously.
Why the “Quadrupling” Claim Is Incorrect
The forum user argues: “If you double the sample rate, the number of samples to be processed in each cycle doubles… In addition, the rate at which the processes have to be performed is also doubled… Therefore the workload is quadrupled.”
This double-counts the effect:
• The “number of samples doubling” already accounts for the faster arrival rate. You’re not processing “twice as many samples at twice the speed “ in some independent way—it’s the same linear increase.
• Convolution (filtering) doesn’t add extra “cycle” overhead per sample; modern DSPs like SHARC use pipelined MAC units optimized for this exact scenario, where operations per sample are constant.
A related (but distinct) case where quadrupling can occur is in non-real-time filter design (not execution):
• To maintain the same frequency resolution (e.g., cutoff at 20 kHz), a filter’s impulse response length (taps) roughly doubles with sample rate (since time resolution improves).
• Combined with twice as many samples/sec, that yields 2 × 2 = 4× operations for implementing the filter from scratch.
• But in running the filter (as in AV processors), you use the pre-designed coefficients at the target rate—linear scaling applies.
This distinction is clear in multirate DSP literature: Real-time execution load is O(fs) (linear in fs, the sample rate), not O(fs²).
