The 9301b supports 16 channels. When it shows AES 1-4 and AES 5-8 on the inputs, that's because each AES "channel" carries two channels, usually called A and B. With the H16-AES the cabling won't be too bad, because the outputs match the 9301b inputs. You'll needI guess I wouldn't miss too much with no going storm given the glm? For 9301, it is limited to 8 channels and lots of aes cabling.. I may prefer to go 9401 AoIP with 16 channels and db25 connection....And I didn't find other digital subwoofers either.
- 2 DB25-to-DB25 cables, like this Avid one or this Mogami one, for H16-AES -> 9301b
- 1 DB25-to-XLRM breakout cable, like this Avid one, for 9301b -> 8 separate AES outputs (with two channels each)
- 8 XLR AES cables out to the speakers/subs + 8 more between the pairs of speakers/subs (see below)
If you use the 9401a, you can route any channel to any of the AES outputs, which makes the cabling more flexible. Note that I think the H16-AIP is legit Dante, which means in AES67 mode it will be limited to 48 kHz. I think others have found the StormAudio is also limited to 48k even with "native" AES67, though. In a Genelec video about the 9401a, they mentioned a variant coming that will be proper Dante, but that hasn't been released, and it's been many months, so I wouldn't hold my breath.
I used Dante for all this and chose to use a DAD Core 256 to do the bass management summing instead of a 9401a (which didn't exist at the time). It does the same thing plus a lot more, but it's definitely less plug-and-play. Then I have a Dante AVIO AES adapter at each speaker (or pair of speakers, if convenient). Then the cabling is just Cat 5e or 6, which, you may have noticed, is significantly cheaper than proper XLR AES cables, not to mention easier to physically deal with and size correctly. You'd need a PoE switch to do it this way, and probably a little networking experience or willingness to learn.
The 9301b has GLM just for setup, mostly. The 9301b does only these simple things:If I use 2 7380 with analog, then I don't think I need 9301 for 16 channels. But if I plan to go digital, I'll need 9301? One thing I don't understand is why the 9301 has glm? Doesn't every subwoofer has glm already? Given 7380 has analog function of this, I think the subs may be out of date.. at least the 9301 digital part should be embeded in the subs like the analog ones. Wouldn't you agree? But then i didn't find any other digital subs...Do you have any to recommend that goes well with Genelec?
- It passes the 16 input channels directly without modification to the 16 output channels
- It sums the 16 input channels (except the selected LFE channel) and outputs that sum to its separate sub output on one AES subframe
- It outputs the selected LFE channel on the sub output on the other AES subframe
I wouldn't recommend the analog setup for more than 7.1, because, aside from the even worse cabling nightmare, each sub would only be able to bass manage 7 channels, which is not probably not what you want.
