Thanks, ya imo the rears are less than 10% of what I hear so I'm fine with less bass, etc. I'm making really nice matching LRCs and I don't want to spend much more atm. I have plenty of material and skills for building cabinets tho.It's generally safer to make a "random" sealed speaker than "random" ported speakers.
But assuming the current design is optimized a smaller box (ported or sealed) is going to degrade bass response.
There is a tester for a little over $100 USD, or you could buy new woofers with known parameters. Then you can get speaker design software to optimize or model the new design. WinISD is free, but if you buy the tester and run the software it might just tell you that a sealed box is the best you can do with the smaller cabinet.
IMO - Rear speakers aren't as critical as front speakers. It's better to compromise the rears than the fronts...
I have "floor speakers" hanging from the wall above my couch as my rear speakers. Somebody gave them to me and they don't match my front speakers.
Hi, I've got some bookshelf speakers I'd like to use as rears. But they're pretty big, so I'd like to convert them to sealed in smaller boxes. Is there an easy way to convert the cabinet volume if I don't know anything about the drivers?
Hey Alex-z! Whoa this is wild! Doesn't seem like something so simple would give good measurements. But I've got all the parts so it might as well try! Thank you for sharing.You can measure the woofer parameters cheaply if you have a PC soundcard and pair of resistors. Dayton Audio Test System does the same job, they just package it for user convenience.
Measure Thiele Small parameters using free software - Audio Judgement
Learn how to measure thiele small parameters, or just a speaker impedance measurement using your sound card. Software used: Room EQ Wizard.audiojudgement.com
Then you can easily calculate the optimal sealed cabinet using VituixCAD enclosure tool.
just glue some MDF to the entrance of the port after you stuffed it.Thanks. I've seen port plugs, never played with them. I'm building enclosures I want to match, since I'm doing so I wanted to shrink these. They're not anything special just SS-CS5s. I'm trying to not spend much money.
But it seems like something that requires knowing the driver specs. Ya?
