Portable USB DAC with it`s own battery power supply anyone ever seen one ?
Update :
Using the above y splitter single end to dac
It will not connect to cellphone using a 6inch usbc cable it only works with fosi audio shorter cable.
There is a sequence to plugging the cell dac and battery bank or power source, if it's not working try another sequence...
The dac operates cooler, the power output has definitely gone up, it's not that noticeable with ATH m50x but using the Sennheiser HD 600 it was absolutely noticeable the amout of detail added prior to adding the external power supply:]
Also plugged the aux end to House of marley bag of riddium speaker and absolutely more detail not as obvious but it's there.
I'm going to measure the output change using a multimeter today I'm curious if I the DX3 pro + would make any difference now, that would save me much $$$
I ordered the below stated usbc male end adapters from Amazon to test outhe connection between cell and splitter, I will post update when they arrive.
Duttek USB C Male to Male Adapter 40Gpbs,USB Type C Adapter Supports 8k@60HZ and 100W Fast Charging, Type C to Type C Male Adapter Compatible with Thunderbolt 3/4 (2 Pack)
Don't think length has anything to do with it. Might it be that connection to a mobile only works when using a OTG cable?
Charging and playing over the USB at the same time: https://www.ddhifi.com/en/product/tc28cpro/
For other like myself : An OTG (On-The-Go) USB cable allows you to connect USB peripherals like flash drives, keyboards, or mice to your smartphone or tablet, enabling data transfer while charging. Must be other applications also ?
Thank you for the suggestion. It is so much more expensive for same task, if it was same price I would chose that design though....
Problem seems to be I need a dedicated data transfer USB-C cable to cell when using a sperate power supply ? OR it`s is a length issue... ?
The Fosi Audio supplied cable won`t charge my cell BUT it powers the DAC and transfers data ( Plays music ) when no splitter is used and no external power supply.
Maybe the other 2 way cable needs more juice when only transferring data longer then the fosi cable ?
The y splitter with separate headphone and charging ports I gave a link to works perfectly with supplied Fosi Audio USB-C cable just the other cable of similar length s a no go, it will charge my cell and do data transfer though...
Same thing is happening on my SMSL SU1 when I connect to my computer using the Y splitter only Supplied Fosi Audio cable works.
It`s a bit confusing with no external power supply no splitter, the Fosi cable powers the DAC from my cell and plays music so it`s transferring data and powering DAC but when cell has power from another source it`s a no go...
Other cables much longer ( 3 feet ) also work with no splitter in the way they power DAC and play music no problems. Same on SMSL SU1.
I`m sure it must related to the length, I`ll know tomorrow when those Duttek USB C Male to Male Adapters arrive...
I just received a fiio RR11 that is a USB Dac with a built in battery and amplifier.
It also has FM radio.
I got mine in silver, but I have decided I want black.
maybe when I get the black one I can send silver to Amir to see how it ranks.
I cannot find any specs so far, but it drives my headphones to volumes well beyond what I need.
I bought this Dual purpose charger / Power supply as I already had high quality Panasonic button top 18650 batteries with circuit protection and four Fenix 5000 mha, 21700 batteries.
I`m feed up with the TOMO T4 I`ve had it for years and never use it due to the circuit screaming every time I use it for power supply, works fine for charging 18650 batteries though.
You can use cell charger or what else for power as long as it`s 5votls DC.
The Fenix below is quiet as a church mouse.
I have other chargers for 18650 a Nitecore D4 & Inlife S4 but they are only chargers not dual purpose. The Fenix is worth the price if you wondering as it accepts the much larger batteries AND it`s very High quality reliable brand.
I don`t recommend inlife it`s cheap I bought Nitecore D4 after Inlife fried a LG 18650 making it hiss : O Mistakes happen D4 is mistake proof same as Fenix D2 Dual.
Sorry to be the guy to break this down but that has no DAC chip so no digital to PURE analog conversion like the Fosi DS1...
Or did I miss something it happens to all of us online researching.....
Maybe add another Type C jack for charging.
It works with the splitter, only when I use the Fosi Audio supplied cable though. I added the link to the splitter I`m using on page 1
About this item​
  • 【USB C Headphone & USB C Charging Adapter】This USB C to Dual USB C earphone jack adapter that supports USB TYPE-C headphone and 60W 20V/3A USB C Fast Charging, allowing you to enjoy music and charge your phone at the same time. Note: can't work with lightning port.
  • 【HIFI audio playing 】This adapter is compatible with up to 32bits / 384kHz while others are 24bit/96Khz. Built-in Realtek DAC Hi-Res audio decoding chip ensures stable and lossless audio signal transmission, no current noise. Just plug and play to enjoy your favorite music.
  • 【Supports PD 60W Fast Charging】 This usb c headphone adapter and charger support up to 60W PD Charging. you can listen to music and charge your phone at the same time. Built-in a powerful EJ899M Chip satisfies the different needs, ensures the stability of charging voltage and current to protect your devices. NOTE: It may not support QC for some new phones. Suggest using PD wall charger to get faster charging speed.
  • 【Super Compatiblity】Suitable for type c smartphones and computers without 3. 5mm headphone jack Support PD fast charging. This type c aux and charger adapter cable is compatible with iPhone 15/15 Plus/15 Pro/15 Pro Max,Sam-sung S24/S23/S22/S20/S20+/S20 FE/S21/S21+/S21 Ultra, Note10/10+/20/20+/20 Ultra,Google Pixel 5/5XL/4/4XL/3/ 3 XL/ 2 / 2 XL, i--pad Pro 2018/2020, iPhone 15/15 Pro/15 Plus/15 Pro Max, Mac--Book Pro/air, Mix2/2s, Xperia 1/5/XZ3 Huawei and more USB C devices.
  • 【What You Get】1 X ZOOAUX nylon braided Dual USB C Headphone and Charger Adapter with 18-Month Warranty and friendly 24/7 customer service. If you have any questions, please contact us and we will provide you with the best customer service.
So the Fosi Audio DS1 is now puling 0.20 amps with the splitter and separate power supply from the cell.
I`m using the TOMO T4 to see the amp flow reading.
So 5 volts 0.20 amps but what does that equal it terms of the out put spec`s 120mW(SE); 220mW(BAL) ?
Am I getting 200mw out of the 3.5 mm jack now ?
It sure sounds like it when comparing HD 600, 300 ohm headphones switching back and forth from this new y splitter setup from the stock one.
Difference is also very noticeable when using AUX jack input of my House of Marley Bag of riddim 2 speaker.
You cannot estimate output power from USB current draw.
But you can measure the Amp output power with a multimeter and estimate output power that way.
Update : the Duttek USB C Male to Male Adapter 40Gpbs,USB Type C Adapter Supports 8k@60HZ and 100W Fast Charging,
DO NOT WORK ETHER !!!
No idea what I'm missing about the fosi cable as it works but no other cables or adapters will connect to cell when using splitter.only the fosi cable.
Chord Electronics Mojo or Mojo 2, these have onboard rechargeable batteries saving splitter leads and extra battery boxes.
I don't know if this is still relevant. I just happened upon this thread. Saw the photo. I'm use a similar splitter but reversed to what you show. I originate the splitter from my Android phone, tablet, whatever. Wife uses one with an OTG adapter into an older lighting iphone, plus C into tablet. All my portable DACs work plugged into the headphone split and recognized from the phone, apps etc. Any standard USB power including a standard belkin battery pack or PD from the wall, etc will charge the phone and power the DAC from the other split.
Fiio also makes a couple of portable DACs with optional power including the new QX13, estick.
I'd love to see how the QX13 tests.
Curious are there any portable USB DAC with it`s own battery power supply as this would allow longer battery life with cellphone use ?
It`s not a problem for me personally just curious of any options and or DYI solutions that do not introduce noise.
Thank you for your time it is always much appreciated.
How many ohms are your headphones that you need one?
The GREAT news is it works with both DAC`s the SMSL SU1 and Fosi Audio DS1, yes I did test them both playing music through other amps.
THE CATCH throwing many people off is it MUST only be 6 inches in length... ?
I don`t have any 1 foot lengths to try but I can say for sure a Quality built brand 39 inch USB-C cable does not work it would only connect to the DAC`s in one direction with the single end plugged into cellphone leaving the power supply charging the cell phone and the AMP draw on the Tomo T4 went up from .30 when only powering SU1 to 1 AMP powering cell that already had 100% charge and SU1 the problem is with some devices if you charge the battery while using the device it can diminish ( DAMAGE ) the battery life very fast so always better to do research before using your devices in this way...
When using the 5.75 inch length USB-C cable that came with the Fosi DS1 it cured that problem now the splitter works both directions so now I can use the single end of splitter in both directions allowing me to use both DAC`s to play music while powering the DAC`s !!!!
I only used the Tomo T4 power supply into the power plug of splitter I had second thoughts of caution when I was about to plug in a quality Samsung 1 amp AC to 5v DC charger into it so played it safe until I have more time to research this.
Thank you for your helps !
Here is a link to the one I purchased for reference sakes.
I've got a few of those but I think another brand.
I have a fiio Alpen 2 that is a dac with a battery I think
I bought it by mistake and threw it in a drawer and have never used it.
