Portable phone Dac
JediMa
Italy
I'm struggling to make work any otg adapter to use my external portable dac with a phone with micro usb. This said I'm considering to use a bluetooth portable dac but my concern is about sound quality, if I'm wrong what I could buy in the 100 euro range?
The Fosi DS2 is a fully transparent USB portable DAC and will work with your Micro USB phone as well as any other:
Well i'm really trying to make it work but can't find a cable or adapter to plug it into the micro usb phone, that's why i'm thinking about a Bluetooth one
Ah, I see your post edit, it didn't say Bluetooth before.
If you're looking for a Bluetooth DAC, then the Qudelix 5K is the best option.
It's got far and away the most mature and developed companion App, chock full of useful features.
Do you have one like this?
You should be able to find any USB cable/adapter you want. I've got a little "kit" of adapters in my laptop bag and a ship-load of different cables. I've also labeled most of my cables and devices so I don't need a magnifying glass to see if it's mini, micro, or C.
It's "Interesting" how non-standard USB has become but it seems like USB-C is the emerging standard and I believe the EU has regulations "mandating" it (maybe only for chargers). But by the time all of the other variations are gone we'll probably have something else replacing USB. :D
[...] use my external portable dac with a phone with micro usb
Just to confirm: are you sure your phone is able to send audio output over the USB connection in a compatible manner? And does it work with just a simple micro-USB to 3.5mm audio dongle?
In a way.. because when I try a cheap otg adapter, it works but music keeps stopping time by time. To double check what should i do to test it?
So IF i wanted to replace the fosi with a bluetooth dac which are my options please?
OMG... my bad sorry . thank you so much Static
[...] the Qudelix 5K is the best option
Is this device at least as good as a TOPPING D10B (or a D10S for 2V RMS unbalanced output) for use cases when I am working at my desk from my laptop / phone?
According to their spec sheet, it provides 2.5mm Balanced 4.0V RMS. In which case:
  • When I am at my home desk, I use a 2.5mm <> XLR cable to connect into my balanced stereo mixer, driven at full 4V balanced line level (instead of using a D10B)
  • When I want to be mobile on headphones (whether around the house or traveling), I just unplug the 2.5mm balanced cable and plug in my headphones (3.5mm cable)
I tried exactly that one and didn't work
This isn't an OTG cable, but a regular one.
And there's no USB-C standard, just a connector.
Could you clarify this?
A quick Goggle search brought me to a document "Universal Serial BusType-C Cable and Connector Specification" that defines the standard for USB-C -- i.e., cables that are used for USB communication with Type-C connectors.
From the Definitions section of the document:
  • Type-C Plug: A USB plug conforming to the mechanical and electricalrequirements in this specification.
  • Type-C Port: The USB port associated to a USB Type-C receptacle. This includesthe USB signaling, CC logic, multiplexers and other associated logic.
  • Type-C Receptacle: A USB receptacle conforming to the mechanical and electricalrequirements of this specification.
Now, a different question is which specific USB version is being used; but they are all still USB.
Thanks for that clarification.
I wasn't familiar with OTG cables. Today I learned that the USB On-The-Go (USB-OTG) standard adds a fifth pin on the USB mini / micro plug, which gives the ability for the smart phone to change its role between being a device (i.e., when connected to a PC) or being the host (i.e., when attaching a device such as SSD drive or DAC).
The only thing I would point out, though - is the 2.5mm balanced output.
I just say this as I'm also looking for a Portable (autonomous) Bluetooth DAC/AMP - albeit just to listen to the TV - So I'm OK with 3.5 anyway.
Still, I thank you for that recomendation.
I don't follow. What are you pointing out?
The 5K has both 3.5mm and 2.5mm
