Portable Dac/Amp for Fostex TH-900s?
mhcapa1
Any recommendations for a dac/amp that would fit well with Fostex TH-900's?
I sorted through tons of headphones and these are the ones for my ears. Looking at frequency response graphs helped me to land on these as well, so Im pretty sure I wouldnt want a dac amp that would change that much, unless it were to emphasize what the th900 chart already looks like.
I had a fiio dac amp, switched to the hipdac 2 because it decodes mqa instead of just rendering mqa, and I mainly listen to Tidal through USB Audio player pro on an android to bypass the android output limiting issues.
The hip dac 2 just sounds a little treble-y to me fr lack of a better term.
Was looking at a monolith thx aaa and a oppo ha-2, but I think asking people in a forum like this one to get advice first is probably better than just buying and trying.
Any price considered.
Any recs?
RickSanchez
Cartographer
Austin, TX
Any recs?
A good place to start is figuring out how much power you need to drive the Fostex TH-900's. This tool can help. That should help you narrow your search for a portable amp that will work with those headphones.
You can use this tool to find Amir's headphone amp reviews:
There's no filter for "portable" but it shouldn't take long to find what you need. There are some solid portable amps that he's measured, the DAC sections measure well and they have a decent amount of power.
Which Monolith are you referring to? This one?
M
mhcapa1
Thanks RickSanchez.
Just used the 1st tool.
Will use the index tool to dig through the reviews and measurements.
Yep thats the monolith
Valuable info. Thanks again
