MAB
OK, so you bought your PA5 about 6 months after I bought mine. And it broke.According to Amazon, I bought it April 10th, but I started building some speakers so I didn't use it till June 1st. I did bring it to my friends house just to make sure it worked so I was quite confident I had it paired up to the E50 nicely. My friend has some huge speaker so we pushed the PA5 to the max and the case didn't ever get hot. Once I got my speakers built, it was working great for 6 weeks and I still didn't feel the case getting warm at all. It was just the past 2 weeks that it just seemed a bit warmer than I remembered.
OK, if I can't get it to work tonight, I'll contact Amazon and the seller. Hope for the best since it matches my E50 so well, I'd rather have another PA5. Besides, it really sounds good.
Yes, these sound good until they break!
I'm sure that nothing in the amp is a huge electrical safety risk (as opposed to the SMPS). More likely is damaging the unit. For instance the volume knob does take quite a bit of force to remove; if the knob is clamped too tight, crunch... or if too loose, then the clamp slips... Both would cause cosmetic damage.
