dasdoing
up
Well it depends a lot on the shape of the FR curve above 1000hz.
I find it difficult to dissociate one from the other. For example, the Airpods Max has a fairly Harman-ish curve below 1000hz, but because the upper mids are comparatively recessed relative to Harman's target, it makes the frequencies below 1000hz stand out more.
Crinacle did, his compensation is not quite harman, but the raw measurements were done with a GRAS 43AG, which should be compliant with the target.Someone measured them??
No it doesn't depend at all! Now please read a poll question as many time's as you need. So it's for and to the curve alone.Well it depends a lot on the shape of the FR curve above 1000hz.
Many think the Harman's target curve for headphones has too much bass. What is your experience?
OK, the Harman curve for headphones has been puzzling me. I have set up a "headphone system" fairly recently which I'm still tweaking when I have time. I've started EQing my headphones either via Morphit, or ReaQ with settings from github (typically Crinacle or Oratory1990 settings). On both my Stax Sigma and Sennheiser 280 PRO, I get way too much bass with occasional distortion, when I use the Harman correction in Morphit, and tend to much prefer their Diffuse Field correction. I'm not done exploring the github settings but they seem to work fine.
Use one of the many Harman Preference Curve presets for your headphone model to experience as close to it as possible?I voted "perfect," but not with a lot of confidence ... I've never heard what that precise curve actually sounds like. I do EQ my headphones in the general direction of Harman, so in principle I like it. I might like a db or so more emphasis in the 100-200 hz area for warmth, slightly less emphasis in the deep bass, and maybe some attenuation in the 2-4khz area, where lots of things sound harsh to me. But that ideal curve of mine would probably look pretty close to Harman.
