- Joined
- Jan 22, 2021
- Messages
- 95
- Likes
- 448
*Updated 6 Nov 2026:
Here is an update to the review report. I remeasured the speaker in a slightly more spacious, yet relatively tight, space compared to my office, updated the layout style, and added a conclusion with an objective performance comparison against the Spinorama.org database and some fixes based on thread feedback.
For anyone curious about the accuracy and validity of this measurement method, you can see a direct comparison of my system measuring a KEF R3 against Erin's and ASR's Klippel NFS measurements here:
https://www.audiosciencereview.com/forum/index.php?threads/how-good-can-a-home-spinorama-in-a-tight-space-be-compared-to-klippel-—-kef-r3-study.74303/#post-2715476
Here is a review and detailed measurements of the Polk LSiM 703, which I purchased in the crazy Adorama sale like 10 years ago along with its siblings, the LSiM 705 and the LSiM 706C center channel.
I think they are great speakers—very smooth, never in your face, and truly enjoyable speakers that look great.
All measurements, data processing, and plotting were performed using LWaves Speaker Lab, a custom measurement software suite I am currently developing. The resulting measurements are very promising, and when paired with a bit of EQ and a subwoofer, the predicted preference score ranks among the highest you will find.
As we can see compared to my previous review of the Philips SoundSphere speakers, completely different speaker architectures can achieve with some EQ a very similar ideal with subwoofer preference scores, yet they will sound totally different. This is mainly due to their distinct radiation patterns and beaming behaviors: while the Polk’s controlled directivity produces sharp, precise imaging, the wider off-axis dispersion of the SoundSphere creates a much more diffuse and spacious soundstage.
The raw speaker
Spinorama
CTA-2034 spinorama
On-axis, listening window, early reflections and sound power, with the two directivity indices below. Flat, parallel curves with smooth directivity indices are what listeners prefer.
Early reflections
The early reflections by wall - floor, ceiling, front, side and rear - and their total.
Predicted in-room response
What a typical room makes of the speaker. A gentle downward tilt of about 1 dB per octave tends to sound balanced; dashed: Harman’s in-room target.
Frequency response
Response linearity
| Level = 0 dB · 85.0 dB · on-axis, 0.3 - 3 kHz | Linearity · −2.4 / +2.8 dB · 80 Hz - 16 kHz | Within ±1.5 dB · 87 % · of that range | Within ±3 dB · 100 % · of that range | F3 · 46 Hz | F10 · 38 Hz |
Each curve against the speaker’s own level: green ±1.5 dB, amber ±3 dB.
Driver components - near field
Each driver and the port measured close up. * = scaled to the woofer’s area.
Directivity
Horizontal off-axis responses
Every 10° from 0° to 90° to one side.
Vertical off-axis responses
Every 10° up to ±40° above and below the listening axis (below dashed).
Horizontal directivity
Level against angle and frequency. Even, gradual narrowing is the goal.
Vertical directivity
The same in the vertical plane.
Horizontal polar
The horizontal pattern at a set of frequencies.
Vertical polar
The vertical pattern at a set of frequencies.
Directivity balloons
The sound in every direction at three frequencies: round = all directions, a narrow lobe = beaming.
Horizontal beamwidth
The angle each side where the level falls 6, 12, 18, 24 and 30 dB below the on-axis. Lines close together and level = a steady beam. The −6 dB beam does not hold one angle (±15°) up to 10 kHz: it spans 94° from 1 to 10 kHz.
Vertical beamwidth
The same in the vertical plane (+ up, − down). The −6 dB beam does not hold one angle (±15°) up to 10 kHz: it spans 96° from 1 to 10 kHz.
Horizontal off-axis waterfall
Every horizontal angle: 0° (on axis) in the middle, ±180° (behind) at the ends.
Impedance
Impedance and phase
The load the amplifier sees: magnitude (Ω) and phase.
Time domain
Phase and group delay
The speaker’s phase and its group delay.
Step response
How the drivers arrive in time: one smooth rising step means the drivers are time-aligned.
Cumulative spectral decay
How the sound dies away after the impulse; a ridge that lasts is a resonance.
Burst decay
How fast each frequency dies away, in periods; a long dark ridge is a resonance.
Distortion
THD at every level
Total harmonic distortion at every level, at 1 m - lightest the quietest, black the loudest.
Harmonic distortion at 86 dB @ 1 m
THD, H2 and H3 at 86 dB SPL at 1 m.
Harmonic distortion at 96 dB @ 1 m
The same at 96 dB SPL - where the drivers’ limits begin to show.
Dynamic range
Compression at rising levels
Each level against the quietest, the drive difference taken off: 0 dB = no change, a dip = compression. Levels: 76 / 86 / 96 dB SPL at 1 m. Grey: the quietest level repeated (±0.04 dB typical) - only a change bigger than the grey is the speaker’s.
Multitone
Multitone distortion (20 Hz - 20 kHz)
32 tones played together; everything between them is distortion, in dB below the tones. Levels: 76 / 86 / 92 dB SPL at 1 m.
Compression from multitone (20 Hz - 20 kHz)
Each tone’s level change against the quietest level. Grey: the quietest level repeated (±0.32 dB typical) - only a change bigger than the grey is the speaker’s. Read 20 cm from the cone; below 100 Hz at 1 m (the port is on the back).
Maximum SPL
Maximum SPL - the speaker with its amplifier
The loudest it can play at each frequency. Black: the limit - the amplifier (Fosi Audio V3 · 48 V 10 A, clips at 30.5 V) or the speaker’s own, whichever comes first. Green: the speaker’s own limit (3 dB compression or 10 % THD), 20-48 Hz. Shaded: still clean at 96 dB. Yellow: music (12 dB crest) reaches 96.7 dB SPL at 1 m - first limited by the amplifier’s clip. Excursion is not modelled (no T/S data).
With its EQ
CTA-2034 spinorama - with its EQ
As above, with its EQ.
Predicted in-room response - with its EQ
Response linearity - with its EQ
| Level = 0 dB · 85.1 dB · on-axis, 0.3 - 3 kHz | Linearity · −3.2 / +1.1 dB · 80 Hz - 16 kHz | Within ±1.5 dB · 86 % · of that range | Within ±3 dB · 99 % · of that range | F3 · 46 Hz | F10 · 38 Hz |
Maximum SPL - the speaker with its amplifier - with its EQ
As above, with its EQ. Yellow: music (12 dB crest) reaches 97.3 dB SPL at 1 m - first limited by the amplifier’s clip.
The EQ used
| EQ | Type | Frequency | Gain | Q |
| The EQ | peak | 65 Hz | -1.0 dB | 8.00 |
| peak | 110 Hz | -1.9 dB | 2.10 | |
| peak | 432 Hz | +1.3 dB | 6.78 | |
| peak | 845 Hz | +1.3 dB | 8.00 | |
| peak | 2.44 kHz | +1.3 dB | 1.60 | |
| peak | 2.95 kHz | -2.3 dB | 1.48 | |
| peak | 4.37 kHz | -1.4 dB | 2.70 | |
| peak | 6.62 kHz | -2.7 dB | 2.05 | |
| peak | 7.58 kHz | +5.7 dB | 1.36 | |
| peak | 9.6 kHz | -4.5 dB | 1.06 |
The EQ
The EQ’s response (minimum phase, as a DSP plays it).
Conclusion - How it ranks
Against every speaker spinorama.org holds measured with a Klippel NFS, all scored with the same formulas.
Data: spinorama.org measurement data - measurements by Audio Science Review, Erin’s Audio Corner and others, each credited on spinorama.org - licensed CC BY-NC-SA 4.0. Recomputed with this app’s own formulas. This ranking is shared under the same licence.
How it was measured
- Microphone: OmniMic (calibrated), at 1.0 m.
- The spin: 36 horizontal and 36 vertical angles.
- In-room, gated at 4.8 ms - room-free above about 210 Hz.
- The bass below 215 Hz from near-field close-ups (the woofer, the port and the mid), joined to the far field.
- Distortion and compression: sweeps at 76 / 86 / 96 dB SPL at 1 m, close-ups below 607-623 Hz (each level its own join).
- Multitone (32 tones): 76 / 86 / 92 dB SPL at 1 m, also read 20 cm from the cone.
- Maximum SPL: calculated for the Fosi Audio V3 · 48 V 10 A amplifier.
- Limits: one unit, measured in a normal room with a gated spin.
- The spinorama follows ANSI/CTA-2034-A; the preference rating is the Olive model.
