Polk Audio PA D5000.5 Teardown and Repair
FraPia-62
I received this Polk Audio PA D5000.5 for repair from a friend. The reported fault was simple: the subwoofer channel was dead.
The amp lives in a wakeboard boat, so it has endured plenty of vibration, moisture, dirt, and heat over the years. In this setup it powers four main speakers and a subwoofer. Two additional tower speakers are driven by a separate Polk amp, while two others are powered directly by the head unit.
According to specs, the PA D5000.5 is rated at 4 × 70 W / 4 Ω plus 1 × 200 W / 4 Ω for the sub. It has adjustable input levels, crossovers, and a subsonic filter.
The amp supports both LR-driven sub and aux-fed sub operation. In this particular installation the sub was driven from the L/R channels. With a total of eight speakers plus a sub, I would personally prefer an aux-fed sub so that sub level is independent of the main speakers. The head unit even provides a post-fader aux output.
That said, I decided not to modify the system and left the configuration as-is. (We can always start a LR-driven vs aux-fed sub debate later :))
A photo of the amp before teardown is shown below. It’s fairly large and shows the scars of marine life, though I cleaned it up before taking pictures.
Mechanical Construction​
The amp feels solid and is built more like a small pro amp than a typical car amp.
  • Aluminum extrusion main body
  • Two die-cast end frames
  • Stamped aluminum side covers with controls and connectors
  • Thick plastic top lid held by two plastic frames
Overall, a robust and service-friendly design.
Teardown​
Disassembly is straightforward:
  1. Remove the four screws holding the die-cast frames and pull them off
  2. Remove the screws from the side lids and remove them
  3. Detach the plastic frames from the top lid
  4. Slide the top cover sideways, taking care not to damage the LED wiring
Inside layout is clean and logical:
  • Top: preamp, crossover, and sub management boards
  • Middle: class-D power amplifiers (main channels and sub)
  • Bottom: two separate DC/DC power supplies
Preamp and Crossover Section​
The preamp offers good flexibility:
  • Accepts 2-ch or 4-ch input (switch selectable)
  • Input sensitivity from 200 mV to 6 V
  • Accepts both line-level and speaker-level signals
  • Full-range, low-pass, high-pass, and band-pass modes
Construction quality is good:
  • FR-4 PCB
  • Mostly SMD components
  • Through-hole parts for pots, connectors, switches
  • Fully analog signal path
  • Uses TL072C dual op-amps
No DSP anywhere in sight, which is not necessarily a bad thing.
Sub Management Board​
The sub management circuitry is implemented on a separate PCB mounted above the preamp.
Features include:
  • Aux sub input
  • Adjustable sensitivity
  • Adjustable low-pass and subsonic filter
  • Remote digital sub volume control
Again, solid FR-4 PCB and mostly SMD parts. However, I did notice a few minor manufacturing issues:
  • Flux residue that was not properly cleaned
  • A few solder droplets stuck to the PCB
  • A thick wire soldered rather roughly (visible on the right of the board). Possibly a test point or late ECO.
The photo shows the board after cleaning during repair, thus both flux residues and solder droplets were removed.
The signal path is analog, again using TL072C op-amps, plus an LM833 for the aux input.
Remote volume control is implemented with a M62429FP (Mitsubishi / NEC / Renesas) dual digital volume control IC, although only one channel (#1) is used. Control data comes in over a serial bus via the REMOTE LEVEL CONTROL RJ14 connector.
Fault Finding and Repair​
The sub power amplifier itself was fine, so attention quickly shifted to the sub management board.
Signal tracing showed that audio was present up to the M62429FP, but nothing appeared at its output. A quick multimeter check revealed that pin 2 (Vout1) was open, while the rest of the chip behaved normally (correct biasing and current consumption).
This strongly suggests a broken bond wire, likely caused by moisture and thermal cycling. It’s a rare failure and should not happen: non-hermetic ICs are normally qualified under harsh temperature and humidity conditions per JEDEC JESD47 (temp cycling, HAST, etc.). Possibly a manufacturing defect that slipped through QC.
The M62429FP is still available, but not cheap (≈ 8–10 EUR / 10–12 USD) and often has long lead times.
Since the remote sub level control was not used at all (not even connected), I chose the simplest and most robust fix: bypass the digital volume control entirely. The added white wire between the two yellow tantalum capacitors directly bridges the signal path. If the remote control is ever needed in the future, the bypass can be removed and a new M62429FP installed.
Main Channel Amplifiers​
The four main channels are implemented using two dual-channel class-D amplifier ICs mounted directly on the aluminum heatsink.
Key points:
  • Single-ended half-bridge topology
  • Very few external components
  • No post-filter feedback
  • Channels arranged to reduce supply pumping:
    • Two channels at 0°
    • Two channels at 180°
Active outputs are:
  • Front Right +
  • Front Left –
  • Rear Right +
  • Rear Left –
The remaining output terminals are grounded.
Supply rails are ±26 V, which is consistent with delivering slightly more than the rated 70 W into 4 Ω.
Subwoofer Power Amplifier​
This section is more interesting. Instead of a dedicated class-D controller IC, the sub amp is built from general-purpose components:
  • TL081 as error amplifier
  • NE555 as ramp generator
  • LM311 comparator as PWM modulator
  • IR2010 high-/low-side gate driver
It’s still a single-ended half-bridge class-D design, powered from ±50 V, which easily supports the rated 200 W into 4 Ω. What’s missing is any obvious provision against power supply pumping, which is typically most problematic on sub channels.
It’s hard not to ask:
Why not use a full-bridge IC amplifier for the sub, powered from the same ±26 V rail as the main channels? That would still allow >200 W output, eliminate pumping, would most likely be cheaper and simplify the power supply. Legacy design choices are likely the answer.
Power Supplies​
There are two independent DC/DC converters:
  • ±26 V supply for main channels
  • ±50 V supply for the subwoofer
Both are classic push-pull designs with a center-tapped primary:
  • No regulation
  • Duty cycle ~50%
  • Output voltage tracks battery voltage
  • Regular rectifier diodes (no synchronous rectification)
As a result, the supplies cannot absorb current, so power supply pumping is possible.
Measured voltages above are with Vin = 13.3 V.
Again, one could question the choice of two separate converters instead of a single higher-power ±26 V supply feeding a full-bridge sub amp. Simpler, smaller, and likely cheaper.
Final Thoughts​
After bypassing the faulty digital volume control IC, the amplifier is fully functional again. It’s back in the boat and working as intended.
Despite a few questionable design choices and minor manufacturing issues, the overall mechanical construction and electrical robustness are very good. Given the environment it lives in, that’s saying a lot. I fully expect this amp to keep playing for many more years.
