PMC result6 Monitor Review
Rate this studio monitor:
    Votes: 225 90.7%
    Votes: 17 6.9%
    Votes: 3 1.2%
    Votes: 3 1.2%
Think about the fact that in music studios, "tools" are required. That is, it’s not necessary for speakers to have a flat response because studios are custom-built for that purpose, and room correction tools are also used. However, having speakers with the highest possible resolution is always appreciated. Are these PMC speakers flat? No. Do they have an outstanding ability to reveal detail? Yes (though not all people are able to notice that ability).
Personally, I’ve listened to them against Neumann KH120 II speakers, and in terms of detail, these PMC speakers were vastly superior. In music studios, ATC and PMC are used precisely for this reason—their ability to extract detail is on another level.
The same applies to mastering studios that use speakers like the B&W 802D2. Their frequency response might look like the Nürburgring circuit, but the detail they deliver is spectacular. And with systems like Dirac or Trinnov, they can be adjusted to achieve a completely flat response.
‘Detail’ is just a region of the FR with more energy than it should have, PMC domestic speakers measure poorly and so it seems does their ‘pro’ range.
All marketing no substance.
Lol, jeah, because of its bad directivity this speaker is not the best do use DSP room correction...
What makes them reveal Details so good?? Right, nothing beside the Dip and the Peak in the frequenzy response what let you think that there would be more Detail. Same with the B&W
For the Money and the usecase for a pro Studio speaker they could and should easy flat. Buy some genelec or Something If you want pro audio.
The whole PMC product Line frome Home to Studio Line has a Rollercoaster Response. If you Like it, nice, enjoy. But when you say its ok to be fooled from them because they claim to be flat, thats Not ok.
You clearly has never listened/used them and only believe in the 'religion' of the 'flat response' ... good for you.
Which, according to your words, means that JBL 305P should be just as good as Dutch&Dutch 8C, right? :facepalm:
Now you are just being silly, perceived detail is purely a heightened region of the FR, learn to understand how measurements correlate to what we actually hear that PMC speaker is a mess.
If you are confusing exaggerated highs for detail, maybe. As I noted in my review, correcting the response using EQ was the only way to get good detail here.
I have listened to both and hundreds of other speakers and my experience is the opposite. As science predicts. Your adhoc experience is without value as you can't prove it.
This is not the right Forum for you.
Youre totally wrong. You answered None of my questions. I heard them often, they Sound ok, i liked the Bass boost (with knowing the Peak there) but there are many better Options out there and they are not to recommend for Studios with seeing that Data now. What do you want to say, we have room Treatment and DSP in a Studio so we dont have to Care about messy Response? Thats wrong in many reasons. And Most 100$ tweeters and woofers (seas, scanspeac,sbacoustic) are better than this used here or in the b&w you mentioned, with better distortion and decay, what Matters for 'detail' resolution also a little. Even the Crossover parts or Electronics used Here are Not nearly high end. Every diy gr-research speaker would be a better Studio speaker for a little Part of the Money PMC wants...
In controlled testing they lose to neutral speakers. In many studies and across many audiences.
It is good for him because he believes in decades of research which top monitor companies follow just well. What do you have to show for your religion?
Now you are just being silly, perceived detail is purely a heightened region of the FR, learn to understand how measurements correlate to what we actually hear that PMC speakers is a mess.
So what?
If some mixing engineers love working on the PMC speakers thanks to the exaggerated perception of details by the heightened region in the FR, and they still deliver good-sounding mixes that make their clients happy, then there is really nothing left for you or anyone else to worry about.
Do you have any evidence that generally points to worse mixing results using PMC monitors than other brands of speakers?
Boosting up a frequency region can be compared to using a magnifying lens, you possibly hear and see more details in that region but at the expense of getting less information outside of it as it will be more masked. Thus it is much more expedient to use a neutral setup and some switchable filters/EQs when you want to do that, as you don't want this to happen at all the time and you want to be flexible for the region of interest, plus the final total balancing must be done with a neutral setup if we don't want to continue audio's circle of confusion.
This is rather a rhetoric argument as it will be hard to find any non-anecdotal proof in any direction (I could say some make good mixes despite the poor tools ;) ) but from the logic I think its clear to anyone that it with a neutral setup it will be easier to create a recording that sounds as desired also on other neutral setups while a deviation from it is not singular.
So what?
In my limited experience I have found that the majority of ‘engineers’ have as much technical knowledge as ‘audiophiles’ ie none.
Their profession is purely subjective, I place very little store in their opinion.
Price play a lot in sound perception of peoples.
When you spend so much , you will not accept you bought bad monitoring, so you keep saying to yourself how good is it.
But data mostly like this no lies.
Even focal alpha 65 are way better more professional better freq response better transient for 10 time less
I have never heard PMC speakers But I very familiar with ATC Speakers Both Brands highly respected in pro studios in England. Both these brand have been measured on this forum and as a result both have generated very negative comments. Here is the issue: As a rank DIY speaker builder with no intention of marketing , not even seeking peer approval, lets look at what is involved: Enclosure, driver, Caps, Coils, Resistances, and much less if your use active crossovers. Not rocket science.
The test results imply:
1) That these companies have survived without this basic knowledge and that they know less about speaker building than rank amateur and audiophiles without experience in the field.
2) That they go to work every day in the process and don't know about measurements.
3) That they have no engineers in their companies.
4) That they only survive because of marketing strategy. I don't see a lot of mainstream adverts that validate these statements.
These questions come to mind, and I know they won't generate many thumbs up, Science is science and measurements are measurement but too many controversies on speakers while electronics measurement result are (justifiably) solid and hardly ever criticized or contested .
Nope, the ability to represent soundstage and pinpoint elements as precise as possible
I have worked with both in music studies as many of my colleages. I guess thousand of multi-tinum records done with that brands speak for theirselves
Experience and skills. By your words I can understand that you are saying actual hit records are a merely luck and not mixing/mastering engineer skills ...
you'd blindly expect a $3000 speaker to be superior
I expect Result6 and similar ATC or ProAc to be way ahead of lp6-305-t5v while being tonally uneven. Yet I might not like that "hollow LMF" signature, cleanness, level of detail, sound stage, ability of speaker to disappear will be far superior.
And why I am not surprized at all;)
It goes back and forth according to whom
It goes back and forth between "PMC is trash" and "if far worse trash costs less then it's not a trash but a feature, be respectful".
And, as I've shown, there are budget speakers that do not distort sound badly. So the "budget argument" is invalid and if it's bad, it's bad. "Objectively". You still might like it and it's okay, totally.
