Pluvia 11 based sphere speaker project
ppataki
Budapest
Now that I am finished filling my living room with 'space balls' I have decided that I will do the same with our bedroom/home office upstairs
The project will be almost the same as the one above but with the difference that this time I will use Markaudio Pluvia 11 (the chrome color version) instead of Markaudio CHN110
I absolutely love the CHN110, I just want to experiment further - I have never tried the Pluvia range before, I am simply curious
Today I got the Ikea salad bowls, the drivers shall arrive next week
I will keep posting the progress, as usual
Stay tuned! :)
A quick update while I am making progress with the build
- the drivers unfortunately won't arrive this week but next week only
- I have figured out the question of the speaker stands; again I will be using another Ikea product which is actually a plant stand :) made of bamboo too (just like the salad bowls used for the cabinets)
See some preliminary pictures attached about setup variations
I will probably paint the speakers white and the stand black - but this is to be decided yet
The drivers have finally arrived!
In my opinion they look beautiful
If I wanted to compare them with the CHN110 I would say that the magnet is definitely bigger (and thus heavier) and the basket is not made of steel but plastic
The screw-holes have a different design and so do the connectors
I am progressing well with the cabinet (essentially it is the same as with my previous project so I will not repeat those pictures here)
I will report back once the 'balls' are put together (hopefully end of this week)
"Nobody goes Ikea for getting things they sold, but for what these things could become", or something similar, is the Ikea-Hack mantra! :D
Have luck with your project!
I am happy to report that the build is complete!
Some photos:
See below some recordings about how it sounds with no DSP except for a low shelf (anyway that is a must-have for closed cabinets)
Next step is to perform some measurements and optimization with Dirac and co.
I will post those too when ready
Any questions/comments please don't hesitate
And now the measurements!
Please note that the placement in the room is not ideal, I have huge room-mode induced dips and therefore distortion in those areas as already highlighted in the previous project.
All measurements were made at MLP (around 80cm), L+R channels, 1/12 smoothing
Let's start with the no correction/DSP measurements:
Actually it does not sound as bad as it seems :)
However, note the phase curve....I would say it is near-textbook
Distortion as mentioned is there due to the room mode dips:
Step:
GD:
Waterfall:
Wavelet:
Now let's see the Dirac corrected graphs:
(note that I did not apply any low-shelf pre-Dirac in the signal path; I have tried it and it will make the low-end look much nicer but distortion kicks-in so I decided not to do that)
Note the Peak Energy time curve.... I think it looks pretty good!
Overall I am really satisfied with the results and subjectively speaking with the sound too!
Unfortunately the room/placement in the room ruins the performance but I was aware of that based on past experience
I might consider adding a sub but since I mainly use my bigger system in the living room I am not sure if I am going to spend more money on this one - will see
For those who are interested I will post more videos about the post-DSP sound and I consider this project to be finished! :)
One remark on that: on top of Dirac I also apply other DSP tools to elevate the highs (which get muted when optimizing the FR to flat - this is normal with full range speakers) and also to boost the lows
Those were not part of the measurements I have posted above
Any questions/comments please shoot
What a great project! I'm considering doing a spherical speaker project.
Given the parameters of the Pluvia drivers (VAS 24.751 ltr) how did you determine that the volume of the spheres was large enough? Thank you.
Thank you, much appreciated!
I always use BassBox Pro 6 to design and simulate the cabinet for any given speaker driver(s)
