D
Deleted member 89782
Guest
No idea what you‘re trying to tell me. I have both.Better check it's music streamer and preamp
Okay sorry I looked at the Ultra not the Amp UltraNo idea what you‘re trying to tell me. I have both.
If you can list your room dimensions and the location of your listening position you will get better advice from people more knowledgeable than me.
That’d be my choice if I were buying anywhere near the price range. I’ve been following its development since the beginning and would likely already have a pair had I not strayed down the DIY path.
My wife would surely prefer I thought like you!I’d like to try DIY eventually — maybe for my home office where I can hide the mistakes. The living room, though, probably deserves something a little more refined than whatever Frankenstein build I’d end up with.
Unlike some of the others commenting here, I think DSP based room correction is an essential component of getting the best sound your can achieve. Further, I'm not convinced DSP is a commodity, and that Dirac ART, Trinnov, and RoomPerfect are probably the best of the bunch. I would keep this in mind, and also consider using two subs to help you get the best bass response results. And... assuming you're going to use subs, probably go with standpoints. All of the speakers you've put on the list are very good ones, while I've not heard them, I would add the Ascend brand to the list.
Use of RC is somewhat divided out there. I think having good dsp to accommodate your circumstances/tastes is a good thing rather than the straight wire sort of approach (which doesn't take into account levels very well). I have several older Ascend speakers, good stuff, and the newer ones with raals would be very attractive to me. I would use subs (and gear appropriate to sub integration) in any case among any of your choices.I’m honestly a bit surprised by how mixed the opinions are on room correction. I’m not adding sound panels all over my living room anytime soon, so DSP feels like the next best option. The space has hardwood floors and is basically wrapped in windows—so I’m hoping DSP can work some magic there.
After going down the spinorama rabbit hole, I’m now strongly leaning toward the Ascend Acoustics ELX Ribbon Tower. I think I’ve just got enough space for them.
You’ve got a very good selection of speakers to choose from on your list!I’m honestly a bit surprised by how mixed the opinions are on room correction. I’m not adding sound panels all over my living room anytime soon, so DSP feels like the next best option. The space has hardwood floors and is basically wrapped in windows—so I’m hoping DSP can work some magic there.
An alternative… Passive speakers such as the ones listed, couple of subs, and a Denon x3800…. My case..I’m new to Hi-Fi. I’ve mostly dabbled with headsets, and now I’m finally taking the plunge to buy some real speakers and an amp. The setup will go in my living room and be used about 50/50 for music and movies/TV. I listen to a mix of genres—jazz, electronic, classical, rock, and hip-hop. I’ve also got some space constraints, so I've mostly considered bookshelf speakers. They’ll need to be fairly close to a wall—about 10 inches (25.5 cm) away.
I was initially eyeing the LS50 Meta + a sub, but then I watched and read reviews of the R3 Meta. Then I got swayed by the Buchardt S400 MKII, which led me to the E50. But after seeing the E50’s frequency response, now I’m considering the A10. I’m all over the place.
*See title*
I think I’ve narrowed my choices down… for now. (Check back in a few weeks for updates.)
Option 1
Option 2
- KEF R3 Meta
- Some sub—maybe KC62, SVS, or something else
- Lyngdorf TDAI-1120 (RoomPerfect sounds compelling)
Option 3
- Buchardt E50
- No sub
- Lyngdorf TDAI-2210, NAD with Dirac, or something else with room correction
Option 4
- Buchardt A10
- No sub
- Lyngdorf TDAI-1120 or another affordable non-amp streamer combo with Dirac
- KEF R5 Meta
- Lyngdorf TDAI-2210 or NAD with Dirac
The R3 Meta setup seems like the most logical first buy-in. My wife isn’t exactly thrilled by the way they look; I think they’re fine. I “demoed” the R3 and R5 at Best Buy today for about 5–10 minutes. The R5 made the R3 sound small, but I was very impressed by both. I had a wow moment with the R3, then got blown away by the R5’s wide soundstage. They both need a sub, in my opinion.
I’m really drawn to the E50’s aesthetic. My wife likes it too, which is a big plus. Everything—from the internals to the cabinet—just screams premium. But spending ~$4.5 K on passive speakers for my first “Hi-Fi” setup feels like a stretch. Plus, I’d probably have to upgrade from the Lyngdorf 1120 to the 2210 to power them properly, which means more $$$. I'm open to other room correction options too, but RoomPerfect sounds simple. After looking at the frequency response, I felt a little underwhelmed. Not sure why I’m hung up on that—my untrained ears wouldn’t be able to tell the difference. I’m sure they sound great and at that price point, they’d better.
To be honest, I’m not sure how I feel about active speakers. They’re intriguing, but when I think “Hi-Fi,” I picture passive speakers + amp. I know that’s an outdated mindset, but still. My only concern is future upgrades—or if something fails after warranty, I’d be stuck replacing both the amp and the speaker. Maybe that’s nothing to worry about.
The Ascilab A6B also look tempting. See title—again.
If you were in my position and had $5–10k to spend, what would you do? Maybe you can sway me in another direction
EDIT: The room is an open floor plan about 18’ x 24’ (5.5 m x 7.3 m), with the living area itself around 18’ x 13’ (5.5 m x 4 m). My listening distance is roughly 14 ft (4.3 m). The ceiling slopes from 15 ft to 9 ft (4.6 m to 2.7 m), with the speakers placed at the higher end and my seat at the lower.
Ascend elx would be a very solid starting point....I’m honestly a bit surprised by how mixed the opinions are on room correction. I’m not adding sound panels all over my living room anytime soon, so DSP feels like the next best option. The space has hardwood floors and is basically wrapped in windows—so I’m hoping DSP can work some magic there.
I would agree .. it's probably gonna take towers+ sub(s) at 14ft for high volume listening...and I would assume some soundstage (imaging) challenges , but that can be adapted for...7-8 ft is my max listening distance and my speakers are 3 ft from the front wall and not near side walls ...Can someone weigh in on that 14 foot listening distance? I'm no expert, but I feel like the usual recommended "hi-fi" listening distance is around 8-10 feet. Does one need to factor a long listening distance into the speaker selection?
www.audiosciencereview.com
The LS60s will do everything you need without “extra” electronics aside from sources.Maybe KEF LS60 would fit your budget? Depending on room, it doesn’t need a sub. If you want room correction, you can pair it with a WiiM streamer.
Also note that the Lyngdorf TDAI-1120 does not have E-ARC, and does no decoding of Dolby or Atmos formats. And a similar amp wasn’t tested very well at ASR. A full AVR may be more future proof, and probably performs better. Denon x3800h seems like a safe bet. Can run Audyssey or Dirac Live (maybe ART at some point), is about half price of the Lyngdorf.
Dirac sounds really interesting, however it only supports a limited range of audio equipment.Not sure why the whole room correction is so controversial. Many traditional methods were PITA and had different effects in different rooms. Or were relatively simple and effective in their own way, like Dirac Bass control (not to mention Sony 3D). But they did help, at least if people knew what they are 1) doing 2) looking for.
DIrac ART is really amazing. Does provide clear benefit out of the box. The ones that have not heard it are probably the ones arguing it is not effective.
