Please suggest a subwoofer amplifier.
JohnnyAudio
My experience and complaints are...
Some of them pop when a signal is applied.
The standby circuit is unreliable.
They overdrive easily.
They burn up in a short time.
Amps I have used with problems
Dayton 2000, Sunfire subs, Fosi M03, QSC, Crown
I also do not want to use a DSP type.
What is the "Dayton 2000"?
Can you describe the subwoofer you have, and what you expect from your subwoofer and a suitable amplifier?
Ok, your need amp with sub crossover? And without DSP at the same time.
https://www.speakerpower.com/products/htb-700 Rigo, general manager and engineer can tweak it any way you wish at no charge. Bought two. One he put in a 12 dB shelf filter starting at 100 Hz for one large sealed sub and the other, later on, I sent it back asking him to remove the crossover filter control to run full range which drives my Ascend Horizon center.
Cheap, powerful, clean. Icepower module.
DSP knob can be plus, O or no DSP, or minus. You have a lot of control.
