Please suggest a reasonably inexpensive power amplifier for my setup
dstrelnikov
Hello!
I've just got the following setup (and quite happy about it for now):
  • DAC: Topping E30
  • Amp: Topping L30
  • Phones: DT 770 Pro 250 Ohm
Now I would like to buy a pair of speakers and hence I need a power amplifier which I will connect to Topping E30. I'm planning on Elac Debut Reference DBR-62. The review is good, I like the design, it fits to my budget and I can easily buy them locally. For this I would need at least a 2x120W power amplifier and possible some reserve for the future (a sub?).
Could you please suggest an inexpensive amplifier which will be good enough as a start? I don't mind eBay (if I can find it in Germany) or some DIY.
I didn't make my mind about the budget but as the initial guess I would say $200. Is it possible?
Doodski
$200.00 might be a little too lean on the budget.
D
dstrelnikov
I don't mind increasing the budget. Just wanted some starting guide and a direction to look at. The "Tier 2" amplifiers from the "Electronics Rankings" look a bit expensive.
piotr_sc
Hello gentlemen, what is the best choice for a 24m2 room. The sound source is Gustard X16
AUDIOPHONICS MPA-S250NC RCA Class D Stereo Amplifier Ncore 2x250W 4 Ohm - 469E
AUDIO-GD PRECISION 3 2020 EDITION Balanced Class A Amplifier ACSS 2x 70W 8 Ohm - 559E
AUDIOPHONICS HPA-S250NC Stereo Class D Amplifier NCore 2x250W 4 Ohm - 660E
TheBatsEar
Germany
What are your speakers?
What kind of music do you listen to?
How far are you from the speakers?
Do you like to crank it to ear splitting levels?
