Hi All,
First post here, although I feel like I have spent at least 40 hours this week reading posts - it really draws you in!
I'm looking to buy my first real (albeit very budget) hi-fi system and would really appreciate your thoughts or opinions on my short-list of kit. First off, a bit of context. I am looking a reasonably small system to fit in a medium sized open-plan living/dining room. This will be a family system mostly used for streaming from spotify or other web sources (I'll probably add some hi-res services to my subscriptions too) - most often used for casual listening. I would love to be picking out a "serious listening" system as well but unfortunately we just don't have the space in our house at the moment! The primary sources will be bluetooth from phones and a Raspberry Pi based streamer (usb output). Even though this will be a budget system I would still like it to sound a good as possible! This will be my first step towards slowly building a real hifi addiction .
I have managed to whittle down to a couple of options which I will present below. I would really love some help deciding which is the better option and if there are any other considerations that I have missed!
System 1 (~£630)
The first was an attempt to create a decent sounding but simple (fewer boxes) system so I went with a set of powered speakers with bluetooth built in. These don't have a USB input so I have added an external USB DAC.
Cons: HD6s are possibly slightly overpriced for sound quality? Less flexibility for upgrading components in the future.
System 2(~£540)
After coming up with the first system I kept seeing post to suggest that a well chosen power amp/passive speaker combo could sound better for the same money as a powered set (especially if they don't need to include BT etc built-in). So I went hunting to build a system for the same budget with separate amp/speaker. Note that I kept the E30 here even though the SA-300 has a DAC because of the better performance.
Cons: Unsure how well the amp/speakers will pair. Slightly more complicated, more wiring. Redundant DAC in SA-300
Final couple of questions to also add:
Any comments on ELAC B6.2 vs QA 3030i? Especially when paired with the SA-300?
I have also found a pair of QAs 3020i speakers for about £70 which I think may be large enough to still fill my room - would these also be a suitable option for System 2 and bring the cost down even further?
Alternatively is there another set of even "better" speakers I could substitute in System 2 whilst not stepping over the ~£630 mark? B6.2/3030i are about £300 in UK at the moment, so something about the £400 mark?
Looking forward to the guidance of all you more knowledgeable people. Thanks in advance!
System 1 (~£630)
- Topping E30 DAC
- AudioEngine HD6
System 2(~£540)
- Toppping E30
- SMSL SA-300
- ELAC Debut B6.2 or Q Acoustics 3030i
