Hi,
I recently sold my receiver and started experimenting with an HDMI 8 channel DAC to DSP and then to amplifiers. Results were very satisfactory but I might be getting some SQ loses in the duplicate ADC - DAC conversion as I've got the DIGITAL to ANALOG from the HDMI DAC, and then again the ADC and DAC of the DSP... so I think I can't get rid of that If I use my computer as a sole source form y media, so I can use it as DSP and also allows me to use a high quality DAC to feed my amplifiers.
I am thinking this:
PC > USB > HIGH QUALITY 8 CHANNEL (OR MORE) DAC >> AMPLIFIERS
For High quality DAC I have the following choices:
-. OktoDAC8 Pro
-. Motu Ultralite MK4 (or similar)
-. miniDSP DDRC-88A
My questions regarding those DACs are:
-. I connect them with USB to my PC, and I willl be able to route/manage all 8 channels independently? I ask because I've experimented with some lower end USB interfaces and there is always a driver problem to output all channels at once and also having control over them (for PEQ, XEO, etc.)
-. Can I use 2 (or more) USB interfaces (very same model) simultaneously to my PC for "doubling" the channels? Just in the case I wanted to go with active XO and needed the extra output channels or if in the future people got a way to decode object based audio by software and needed more than 8 channels...
-. Can I use any software (like EQ APO) to manage the interfaces or do I need a specific branded software? Will this branded software be compatible with PC's video players like Potplayer or JRiver?
-. Can I input 8 analog channels to my interface, process it, and then output thru the DAC in real time without too much delay? That way I might be able to also use another media source, although I suspect SQ would be worse as I would be adding a DAC before the ADC of the interface.
This setup would be used strictly for home theater/gaming use, just in case anyone cares.
Looking forward to you help and knowledge.
Cheers.
I am thinking this:
-. OktoDAC8 Pro
-. miniDSP DDRC-88A
Cheers.
