Please help in understanding and choosing - CBM-170SE2 vs F6B vs C6B
John.D
Forum members, please help in choosing among these. Is there tangible benefit from going 500$ >> 1000$ >> 1450$ in the following speakers?
Not worries about looks.
I will pair these with a budget subwoofer (like Dayton cs1200 or RSL) crossing at 60 - 80 Hz.
Your input will be super helpful.
how does that directivity difference impacts in listening?
Oversimplified, it's the difference between diffuse and precise sound stage/imaging.
It's controlling the ratio of direct sound to reflected sound that will reach your ears.
Bare walls <-> Acoustically treated room
Mid/far field <-> Near field
Flush mounted tweeter <-> Waveguided tweeter
The right side will have you listen more to the music itself whereas the left side will have you listen more to the room the music is being played back in.
No right or wrong in this case, just different flavors.
Is C6B about different looks only? No better bass performance or any other benefit?
The C6B uses a different woofer and tweeter. However, there are no clear performance benefits from them as far as I can tell.
But you can judge for yourself:
The cabinet and waveguide stay the same.
CBM170SE2 review thread has some kind discussion going on about soundstage vs center imaging.
I don’t want to jump in there to throw in my uneducated questions and so putting it here:
Amir didn’t suggest any imaging issues or caveats about it, he specifically mentioned spatial experience which I guess is about good soundstage.
Please someone help explain this here if possible.
Science has not fully analyzed this area. My subjective, read unverified, opinion is that without a waveguide, you get wider dispersion which then results in larger, albeit, defused image which I personally like. The cost can be awful off-axis response which will make the speaker room dependent as those reflections don't match the on-axis response. In the case of Ascend speaker, clever and tedious testing/optimization have managed to bring the design cost under control with a predicted in-room response that is well behaved. But I think the risk of room dependency remains.
I am biased so I can't answer your original question with straight face. :) I will just opine that the difference is getting a speaker with less spatial effect with higher assurance of it sounding good in your room (Ascilab speakers) vs higher reward of better spatial effect but with potentially more tonality issue in rooms not represented in the research.
Also, please keep in mind that not everyone is like me, wanting a diffused halo instead of "pinpoint imaging." Most people are like me, but not all.
I am actually tempted to ask Dave to let me keep the speaker as to test against Ascilab as to be able to better answer these questions. Alas, I think he wants my sample back for additional testing (my results are slightly different than his).
The F6B uses a much less expensive woofer, the plastic-framed, paper cone SB Acoustics SB16PFC. This is my favorite BUDGET woofer, but it is a budget woofer. It uses the SB26ADC aluminum dome tweeter.
The C6B uses the much better SB17CAC35 ceramic coated aluminum woofer. It uses the SB26CDC tweeter which is a ceramic coated version of the SB26ADC used in the F6B.
EDIT: You can look up the woofers on Madisound but basically the SB17CAC has a larger voice coil, larger magnet, much lower inductance, better power handling, and greater xmax. Compare the 3rd order harmonic distortion at 96dB in Amir's review of the F6B and Erin's review of the C6B and you will see what the difference between a budget driver and a more premium driver.
Never thought you would chime in here but super glad you did… many thanks.
And, I would rarely think your opinion would be biased.
That would be a great real world scenario to test!!! Hope Dave can help with that.
I tend to find most speakers are bit too wide, the ascend would probably be a bit too much for me.
I dont actually find the ascilab to sound narrow at all, they sound plenty wide. Ascilab has one of the best tweeters you can get, compared to ascend distortion is like 15db down at ~2khz and its using a much lower xover. Those sb are just on a different level than the ascend tweeter. The DI is in a different league. Its not easy to get a di that smooth, and you are certainly rewarded if you can achieve it. I am consistently impressed by how good everything coming from the ascilab tweeter sounds.
Im not the biggest fan of the widest part of the tweeter on the acend being ~5khz. But, they are also much cheaper and I like money. The woofer looks to be good. If the budget affords ascilab id get those no question.
Thanks to all of you who added you bit here and surely helped.
But I am more confused now. So putting my thought simply:
> I can read from all of you that ASCILAB are technically superior with lots of controlled dispersion
> Does ASCILAB not have or lack the holographic soundstage and spatial presentation like Ascend?
Questions like this don't have any answer as there is no proper evalutaion of this.
Thanks @amirm
You have reviewed Ascend and Ascilab C6B just now, what's your subjective take between two?
You are a trained listener as well, perhaps best person at the moment to provide some opinion.
By the way, I downgraded to a townhouse now and this is for my work room 12 x 10 feet. Placement option is on the 12 feet wall with 6-7 feet distance between them (between speakers I meant), and side walls about 3 feet to each speaker. No space behind the seat, just drywall.
I didn't have them side by side. Spatially, I remember Ascend projecting a larger image when listening to one speaker. You are asking for imaging for two so I don't have that.
My impression of overall sound is that C6B did sound warmer to me in a good way. It played cleaner but then distorted harder in very deep bass. In upper bass this was not a concern, i.e. most music.
Of course, it is a far better looking speaker with seemingly much better build.
My main intention was performance regardless the price difference.... but you are right.
I'm going to say, based on measurements the CBM170 v2 is very close in performance to the Sierra 1 v2 ...I agree with Amir and Dave in thinking *most* folks prefer wide dispersion in most set ups...if you like an " airy " open soundstage they are the general pick in most rooms.. The ascilab speakers will sound good in more challenging circumstances more often( bright rooms, with lots of exposed glass and not much furniture would be one example) ....the ascilabs will also be your preference if you want a very focused center image at the expense of some soundstage width and the " air" I referred to ... Since the ascends are pretty budget friendly I'd try them first, if you like them keep them and forget about which speaker is "better".... just enjoy the hobby.. If you don't like the results, get the ascilabs and try them after you return the ascends.. Best of luck , enjoy your listening....
