tmtomh
- Joined
- Aug 14, 2018
- Messages
- 3,505
- Likes
- 10,601
Rockwool is not affected by humidity. According to them, from Why does moisture repellence matter?:
Ah, I see. Thanks for that information!
It's likely off-gassing/degassing of the rockwool... is your room ventilated properly?GIK Acoustics panels have always smelled a lot
Although after 3 years I would expect it to have dissipated by now. The fact it hasn't makes me wonder regarding sufficient ventilation.if I don't air the living room regularly
One 23 inch × 23 inch tuned bass trap that only works at a specific narrow frequency range and is installed in a random location, and it doesn't produce any significant effect? Sorry, that's to be expected.About a year ago I bought two of their Scopus Tuned Membrane Bass Traps tuned to 70Hz, zero impact both in measurements or subjective, they just didn't work at all, 320€ right to the trash can
Why do you assume it was random? It wasn't insignificant, it was nothing, how many more do you think I need if two showed 0 change, 500? The whole point of this specific trap is its size to efficacy ratio, anyway I went with proper custom traps which were cheaper and actually worked. Their marketing materials are misleading at best and made up at worstOne 23 inch × 23 inch tuned bass trap that only works at a specific narrow frequency range and is installed in a random location, and it doesn't produce any significant effect? Sorry, that's to be expected.
Funny you mention this.I have four GIK panels and they don't smell. I also made some simple unframed panels - in other words just rockwool stuffed inside jersey (t-shirt material) pillowcases - and the rock wool I got from my local home/hardware store doesn't smell either.
I wonder if long-term slightly high humidity could create a mildew smell or something? The insulation made from recycled denim contains an anti-fungal agent or mold inhibitor for this reason I believe, but I don't think rock wool contains any such additive.
Do you know where the pressure maxima of your room modes are?Why do you assume it was random? It wasn't insignificant, it was nothing, how many more do you think I need if two showed 0 change, 500? The whole point of this specific trap is its size to efficacy ratio, anyway I went with proper custom traps which were cheaper and actually worked. Their marketing materials are misleading at best and made up at worst
yes, though it seems like you know betterDo you know where the pressure maxima of your room modes are?
You can cover them with one 23 inch × 23 inch trap?yes, though it seems like you know better
I never said I had one, I tried the amount the GIK rep told me to, also please leave me aloneYou can cover them with one 23 inch × 23 inch trap?
I am here to counter mis- or disinformation. How many did your 320€ get you? That's about the list price for 1 piece.I never said I had one, I tried the amount the GIK rep told me to, also please leave me alone
I wouldn't be so sure about your claimed goal, yet once again you prove yourself wrong, it's not the size you linked but still it shows 183€ here (ex. vat). Don't bother to reply again as I won't see it anywayI am here to counter mis- or disinformation. How many did your 320€ get you? That's about the list price for 1 piece.
OK. 2 pieces, 8 square feet total. What's the total wall area of the room, and percentage coverage? It takes some basic knowledge of acoustics and room acoustics to properly apply acoustic treatments.I wouldn't be so sure about your claimed goal, yet once again you prove yourself wrong, it's not the size you linked but still it shows 183€ here (ex. vat). Don't bother to reply again as I won't see it anyway
No, but I found a post on the web where a guy opened a premium panel and the non-woven fabric is clearly visible.@Raticosa
Out of curiosity did you also opened the panels from Addictive Sound? I'm curious to know if everything is OK there.
Could it be not putting any layer of "non-woven fabric" is a standard "industry practice" around our part of the world? (I'm from Italy too)
I will try to reply to some questions:You can't return the "smelly" ones?
At the beginning, the first two or three weeks, they smelled a lot but this is quite normal, they remained in their nylon envelope during the transport and probably at the factory too. After some weeks the smell reduced but it never disappeared completely, sadly.I stopped reading at "smell" .
I would do detective work if that happened after sometime and it wasn't there at the beginning.
Did they smell right at the beginning?
I have a big problem with smell,sometimes even with the packaging that comes with some stuff!
Mine are built in Poland , all they come from here.No smell with my panels, and I have 19 of them in a 4.4m x 3.4m x 2.4m room, there may have been an odour when new 4 years ago but I can’t remember if this was an issue or not at the time. My panels get vacuumed on a low setting quite regularly by my mother, she’s one of those “clean freaks” (luv ya mom but please put the duster down and step away from the cleaning products) and never commented on fibres coming through the outer fabric, I’d notice them as my 4 tri traps are black and show up the slightest spider web etc.
I’m pretty sure there is a layer of permeable material covering the insulation material on my GIK panels, perhaps they are built differently in the UK
