- Thread Starter
- #141
No, never used any filter before, because DSD256 was stable. Just recently started with DSD512, but that was unstable, which led me to try the filter.
Well that's good, you are lucky. The PC doesn't generate that much noise overall.
Filter is not connected to either case. It's just the existing USB cable (4 to 6 ft long) wound, as many turns as possible, around the toroid with the ends short as possible to connect DAC and USB jack of PC. This kills any PC noise in the cable, preventing it from getting into the DAC. Toroid is very close to the DAC (about 4 inches), and the PC end is about 1 foot long (DAC sits on top of the PC). Note - my DAC has it's own AC power, I don't take DC from the PC for power, don't know if that makes a difference.
Ok now I get it, I'll try with the HS-02 and take some measurements. Why not.
What images are you playing (DSD images ?).
No, I mean media; cover, booklets, etc. The x32 version was a disaster, the x64 could handle it much better.
Now the x64 version never crashes, not sure about the x32 since I don't use it since ages.
I am sticking with 32 bit, because it's working so don't see a need to change and create more hassles.
Also, I use a 32bit component that I don't want to give up - foo_musical spectrum.
If you don't have a specific need, I agree.
Stick with your current version.
x32 is also less resources demanding.
All plugins I use are either compiled with the x64 runtime or are x64 so I don't have legacy to mind.
I've had mixed results with him on Sourceforge - one time he responded quickly, another he totally ignored my question. Maybe next time I'll try emailing him.
Just ping him again
It's not really state of the art this Sourceforge system.
I haven't see anything (in Sourceforge) that refers to 64 bit, these components were developed for 32bit (far as I know, correct me if wrong), that could explain some of your issues.
It doesn't really matter if they are x64 or not, they just need to be compiled with the latest runtime.
The DSD Processor is probably x32 while ASIO+DSD is x64.
