Get one ASAP!
I use E-MU for a while since I already had it but I plan for a good one,it's eye-opening and absolutely necessary to set-up and test stuff.
Got your advice and bought a Focusrite Scarlett 2i2 3rd Gen.
The Behringer was really utter trash... I bought it to use it for Room EQ but it's so bad it would have surely messed up also the mic readings.
Do you still have the Khadas Tone board? Can you try again with the latest MTA?
I'm surprised is so bad with DSD.
I wonder if there's something wrong with the board/drivers or maybe something was off with that version of MTA.
I have some weird issues testing DSD with MTA but could also be it's because of the awkward method I have to use.
Neither the Aune X8 or the Topping D50s are supporting DoP via USB.
For some reason I can't manage to use the integrated Realtek SPDIF Optical, neither with PCM or DoP.
My only way to test it is using the foobar2000 ASIO DSDTranscoder driver.
Maybe you can try that as well.
To use it you need to keep open foobar2000 in the background without anything playing or in pause.
There's a drawback as it doesn't work very well. DoP is engaged/disengaged in a flip/flop basis.
Hence it's impossible to use it with a multi step measurement; every each one I have to stop, clear and restart.
But it's fine for the MT32 test.
I have tried to replicate your for comparison.
That's where I had the useful but not so funny confirmation that my USB is incredibly noisy.
Usually also with strong harmonics at 4/8/16 kHz.
Was already suspecting it cause I could see random weird stuff with the scope.
I managed to find one USB port, the BIOS Flashback, which is slightly better but not that much.
Today I should get an Audioquest Jitterbug but I'm not so sure how much it can help.
I have ordered an ISOUSB211 eval board for full galvanic isolation but it will probably arrive only next week.
In summary up to DSD128 the quality is same as PCM 96 kHz; going to DSD256 there's a sensible drop.
Not sure at that level is audible but probably doesn't make sense to go DSD256.
Same goes for PCM, going higher with the rate will decrease all the figures.
But even with PCM going higher seems causing troubles with MTA, probably something wrong with the drivers.
The Aune X8 is doing a slightly better job handling the noise than the Topping D50s, seems.
But I have tested it before hunting for a better USB port.
Still not enough to justify the price difference in my opinion.
I've only tested briefly the JRC5532 op-amp with the Topping and it was worse than the stock 49720NA, especially in handling the harmonics.
On the Aune X8 the OPA2134 was slightly worse than the others but it's hard to say. Over many runs was always a tad worse.
This is the best reading I got with the D50s and 49720NA with PCM:
This is the best reading at DoP64:
This the best at DoP128:
At DoP256 there's a small decrease in general but the biggest problem is that the harmonics becomes untamable:
This the the JRC5532 at DoP64:
The Aune X8 with PCM and JRC5532 on the sub-optimal USB port was doing already a decent job, better than the D50s:
And it was doing well also with DoP64:
Not so good at DoP128:
But the 49720NA somehow managed to do better with the harmonics at DoP128 (maybe just cause it was tested 5 minutes later):
They all had the same figures at DoP256 like the 49720NA:
Just a tad worse the OPA2134:
