worker24x7
- Joined
- Dec 19, 2025
- Messages
- 14
- Likes
- 8
Does anybody know where one could procure those plastic pad mounting ring for the Denons?
Denon 5200 and D2000 specifically (these have different mounting rings).
I had checked Geekria, Dekoni -- they only sell pads, and ask that you pull out and reuse the existing plastic rings
The plastic rings have mounting tabs that often break, unfortunately -- and they are essential to the assembly (cannot be without them).
This Geekria video shows the D2000 mounting ring (white plastic ring) being pulled off the existing pads
shop.geekria.com
Denon basically said to go and by from their parts supplier the whole set of pads ($80)
https://encompass.com/item/12583403/Denon/917439101460S/
917439101460S, EAR PAD L/R ASSY AHD5200
I cannot find just the plastic ring part (which should be inexpesnive, and Denon already manufactures it...)
I also checked thingiverse for 3rd-printed parts... nothing.
Therefore wanted to ask here for any ideas.
Geekria QuickFit Protein Leather Replacement Ear Pads for DENON AH-D2000, D5000, D5200, D7000, D7200, D9200 Headphones Ear Cushions, Headset Earpads, Ear Cups Cover Repair Parts (Black)
Product Features Replacement earpads made with high quality memory foam and protein leather. Replace your worn-out earpad cushions / ear cover / ear cups. Give your headset a new earpad. Make it a brand new look. Durable and long lasting, quality made ear pads. Compatible with DENON AHD9200...
shop.geekria.com
