Hal Saunders
- Joined
- Jan 7, 2026
- Messages
- 5
- Likes
- 0
I haven't (other than headphones) had a proper sound system for several years.
Recently I've really started to miss it and want to set up a basic but quality bedroom system to listen and just chill out and also for when I'm editing photos, which I do quite a lot of.
The Wharfedale Diamond 12.1 will suit my 17 sq/m room, and my listening tastes very well but there is one placement hiccup. They must go on a 3.6 metre wall which has the bed in a central position and I will be flat out getting them 30cm from the sidewall. Distance from the rear wall isn't a problem.
Nearly everything I've read is that they need heaps of free air to sidewalls and every online YouTube review has them virtually in free space.
How badly will close proximity to side walls affect the sound and how effectively do you think I could remedy it with sound deadening pads or doing a room eq adjustment?
Hoping I can use the Diamonds, the more relaxed nature of them is exactly what I'm after.
Thanks in advance
Thanks in advance
