Looks really nice, like modern vintage, but what about diffraction effects with angular enclosures? They say that’s the worst possible shape for a speaker cabinet.
On one hand, their Tenet looks impressive, but also a bit too... hmm, too simple— I write about enclosure. It looks a bit like a mid-range DIY project, though I could be wrong.
A valid concern. Check out its
CEA2034 measurements on spinorama.org.
It's easiest to see those effects on the contour plot, but unfortunately that's not available. You look for "fingers" or "lobes". So we have to learn to spot diffraction in the summary window instead, which is much more difficult. Diffraction is almost always a mid-treble phenomenon, between 1kHz - 10kHz (wavelengths 34.3cm - 3.43cm). Longer than that and it doesn't interact too much with the cabinet. Shorter than that and the diffraction effects are evanescent and mostly disappear at the listening position. So we only focus in this region.
It helps if we have a "bad" speaker to use as an example, so we will look at Amir's review of the
Fluid Audio C35BT:
Here we can easily see the diffraction between 3kHz - 8kHz.
EDIT I am a numbskull, I showed the vertical directivity instead of horizontal. Never mind, it still shows you what to look for.
It's much harder to spot on the CEA2034 summary window. First we focus on the
red square - that's a resonance. Why? Because there is a sharp peak, and it persists across the LOW, ER, SP, SPDI, and ERDI. Now we look for the diffraction in the
green box. It's there, but difficult to see. What you are looking for is a ripple in the LW and ER that
is worse compared to the on-axis. But since the on-axis is by itself rippling up and down, we normalize it and now it is easier to see:
Note how that ripple disappears in the ERDI. In contrast, the resonances at 1.2kHz and about 15kHz do not disappear.
So go back and look at the CEA2034 of those P&G's. Yes you will see some diffraction, but it's absolutely tiny. It won't matter. About the only criticism is the slightly negative DI below 50Hz and the notch in the SPDI at about 900Hz (probably at the XO point), but these are far from the worst I have seen. The other thing to see is that the ERDI is about 10dB, meaning these are speakers are more directional than most. It's not "good" or "bad", it's whether it works for you or not. You will likely need to toe them in. That CEA 2034 is near perfect.
These measurements are incomplete. There is no step response, no distortion measurements, no vertical directivity, and no compression testing - so I can't comment on those. And of course, these measurements were supplied by the manufacturer and not by an independent third party. I would very much like to see Erin review these speakers.
Nobody is going to complain that these are bad measuring speakers. With the proviso that we don't have all the measurements, and the info is manufacturer supplied. This is a world class speaker which deserves a worldwide market. If they wanted that, they could get Erin to review them and they would have that market. It's not up to me to comment on their business practices, but my impression is that they are a small operation that hand builds every speaker. In every business, massive demand isn't always something you want.
