Not surprising that the AVR didn't take more than a few watts, and I would repeat the following that people don't realize:
- How little "power" they actually need, from their amps, receivers, or AVRs. (example: speakers have decent sensitivity such as 87 to over 90 dB/2.83V/m, near field, 2-3 meters, in small rooms, listen to nowhere near ref level).
- How often their amp, receivers, or AVRs clip when listening to music or movie track contents that have high dynamics. (example: Copeland Applachian Spring CD version, Hobbit, the dragon scene)
Both could be true.
pretty hard to "hear" clipping, yes.
This is a measurement I made at the old place, with the AVR in pure direct stereo mode, UMIK-1 into REW on my Laptop, feeding the AVR with RCA cable; only the right speaker playing.
The SPL meter was somewhere around 94-95dB, which is WAY beyond anything I ever listen at. (94dB average on the noise, that is!)
3m listening distance, large room (roughly 30sqm - which is huge by European standards) with Living room and adjacent open kitchen and dining area, as well as a 6ft wide opening to the hallway.
(no subwoofer in use, just the Floorstanders somehow generating 20 Hz at 95dB )
As you can see, distortion was quite pronounced at this point, but this is probably beyond the limits of these 30yo speakers anyways, considering that corresponds to over 110dB at 1m distance.
At 90dB/1W/1m (rated sensitivity by B&W), and a distance of 3m, the speakers would've been drawing between 5 and 50 Watts here.. (for 100dB, the peaks at 43 and 90 Hz are room modes)
With the minimum impedance at around 3 Ohms between 80 and 300 Hz, it looks like the Amplifier did fine?
Here's the same measurement using my tube amplifer (Destiny Audio EL34, with 2 x 35W from 2 EL34 tubes, each). SPL was slightly lower at around 90dB, and you can see how THD amounts to the same..
I'm no expert here, so I cannot say for sure what I'm looking at..
The AVR couldn't quite produce linear 100-200Hz.. could that be due to the 3 Ohm impedance? (because the tube managed it)
The tube produced audibly and measurably more pronounced rolloff past 8 Khz, which is something I really liked about that amplifer.. warm and all that..
I know that tube amplifiers distort more "nicely" and therefore are often preferred in that range.
Are we looking at that "pretty clipping" here?
full disclosure: those were not scientific tests in a sound deadened chamber.. the tests were conducted within minutes of one another, letting the tube amp warm up after switching to it on the amp-switch box. You can see the very high noise floor (dark brown square wave looking in the background) due to the kitchen with the fridge and other appliances humming away.. I already had my NAS at that time, too, which also produces a constant backrgound noise.
But I did not switch anything regarding the curtains, carpet, pillows on the couch, microphone stand (tripod) or position, etc.
I myself put myself into the hallway, to be "out of the way", but I did not leave the apartment, lol..
I sold my tube amp and currently don't have the space to compare the AVR to my Yamaha Stereo amplifier, but I'd be curious to see how the system measures now, in the new room..
Maybe when we get our own place.. I'm dreaming of a proper home theater with thorough acoustic treatment and all that..
