If you read the FTC requirement for measuring rated power it states that it is to be read after 5 minutes of continuous running at that power.
Pioneer’s website lists the FTC power rating:
120 W/ch 8 ohms, 20 Hz-20 kHz, THD 0.08 %, 2ch Driven FTC
This AVR cannot run at anywhere near its rated power for more than 35 seconds.
Martin
From the Onkyo RZ50 Review:
Clearly there is some monitoring going on internally causing the amplifier to go into ECO/power limiting mode. With 8 ohm load, I didn't see this problem:
@amirm - given the two AVR's have identical power amp boards with presumably identical nanny circuits - there is a substantial cognitive dissonance in showing the RZ50 as not having any trouble passing the 8ohm test, and the LX505 flunking out.
In fact the 8ohm LX505 test looks like the RZ50 4 ohm test:
Given this problem I could not run my max and peak power. But did run my frequency sweeps post a power cable removal:
It seems to me that either this LX505 sample is faulty/flawed in some way, or, there may have been a mixup in testing, and it was in fact setup for 4ohm?
I agree with others that if the 8ohm test hits power limiting at 20W to 40W after 35s, then there is a serious problem.
Skimming through it, I assumed that graph was a mislabelled 4ohm graph as it matches what I expect from this family of AVR's on 4 ohm continuous - but if it really is, as labelled, an 8ohm test - then I retract much of what I said... something is definitely wrong.
