Pioneer VSX-LX505 AVR Review
Rate this AVR:
    Votes: 179 63.9%
    Votes: 47 16.8%
    Votes: 44 15.7%
    Votes: 10 3.6%
That is your opinion. Your argument would have more merit if the benchmark power output at 8 ohms was short of the FTC rating, but it wasn't!
If you're going to be upset, shouldn't you be upset at the FTC? All makes are being benchmarked the same so I don't understand how it's "unfair" to Pioneer, Onkyo, and Integra.
Fair enough, I suppose..
Then again, you keep ignoring my statement about Amir overdriving the amplifier.
He used +2dB volume, which is basically driving a car in the red rpm range.. sure, it produces a very nice 20% higher power than the advertised numbers.. But it's not the value you want to test for.
At 0dB, the amplifier probably would've put out 120dB (thereabouts) and sustained that, as per FTC guidelines.
Now, did Amir ever test 4 Ohm at 0dB volume setting, or below that setting, like a realistic test would require?
Nope.. he insisted to overdrive the amplifier at +2dB and saw that it could output 140 Watts into 4 Ohm, then cut power because it tried to protect the circuits.. You can criticise the design or manual exclusion of this protection all you want.
We know that it doesn't affect real-life use ever..
But we don't know if it would appear on a test bench where the AVR is used at 0 dB volume setting, instead of in overdrive mode..
why try to get more power out of it than it is rated for? that only shows headroom, not actually whether the amplifier is within RATED SPEC.
I criticise Amir's test for two things:
- ignoring the real-life application of such amplifiers
- overdriving the amplifier and criticising it without ever testing it in "normal" mode
(remember how he noticed that the amplifier delivered BETTER SINAD when NOT at +2dB on the volume knob? (set to 0 dB, the output voltage was lower, which is why Amir insisted to overdrive it, because he somehow insists that 2V must be the standard.. but at 0dB volume, the SINAD of the amp would've been in the green, even.. all ignored just for the lulz..)
IMHO this would be wrong too. You should test device the way it is used. For power amp you set gain (if possible), and then input test signal with variable level. For integrated amplifier with preamp and volume knob you input test signal at nominal, constant level and use volume knob to get characteristic.
Amir is doing power amp test for integrated amp and this leads to some errors. For example, you can get different results depending on volume knob position.
I understand your point. However, all 4 ohms tests were performed the same regardless of make. Are we to assume that makes other than Onkyo, Integra, and Pioneer somehow overengineered their amps to perform decently in a 4 ohm test? Who's ever complained about that?
That's still not a good look for PAC AVRs, however you try to frame it! Trust me when I say PAC doesn't need us defending their products (no apologists needed) as the majority of the population won't notice the difference in audio quality (exception being folks like @dlaloum and other audiophiles). They've made their money and the new line of products coming out in '27/'28 is going to go through the same tests on ASR. Will the new line bench better on a low impedance load? Only time will tell...
Personally, I’m very happy that I purchased this for $700 including taxes. It has been running without issues for the past 18 months and including Dirac live in the price is a bargain. I’ve pushed it to -3db while watching movies with friends and it never had an issue. I do use an external amp for the front L/R though I think the AVR doesn’t turn off its amps so it’s still running all channels.
I’m also not sure why the fans never came on during Amir’s tests; mine come on constantly when playing music higher than -25db. Maybe the unit he tested was defective ?
Behavior can be changed via firmware. I believe a 505 is in the queue for Amir to re-test based on updated firmware that supposedly removes the "limp mode".
Has nothing to do with over-engineering, though, has it?
Amir is fixated on 2V output via pre-outs, and that's why he had to select +2dB on the volume knob for his initial tests.
the 2V output is not industry standard and only Amir decided to enforce that.
(he admitted in his tests that the results were worse than at 100% (= 0dB) output volume level, indicating quite clearly that the amplifier is running beyond its limit.)
But that 2V BS has got ZERO to do with how you test the internal amplifier!
Yet, Amir insisted on keeping the volume knob at +2dB..
that is the part that I criticise about the testing method.
He didn't even BOTHER to try and see what happens if the volume is set to 0dB or less.
Did he test the Denon at +2dB volume setting?
Nope, the tests were conducted at +82 or something volume.. (quite a lot below max volume, actually)
Afaik, and according to Amir's review of the x3800H, the Denon cannot even provide 2V output.. it clips at 1.4V, and Denon claims that this is plenty enough for users with external amplifiers (lol)
I've got the newest firmware on mine. It sits in a closed cabinet, gets used daily, and gets very hot.
Have yet to hear fans spinning..
What I do still observe is the power-saving mode with the switching PSU switching to the higher voltage rail when I turn up the music.
You get well above 2V for each channel where "Pre-out Only" is selected. There is no such "pre-amp mode" option for PAC AVRs until you get to the RZ70, 805, DRX8.4 level.
Note: that's an internal Denon slide in Peng's post.
Remind me again which speakers you are using in your setup and if you're using external amps?
B&W Nautilus 803 fronts (89dB/1W/1m with very low impedance floor), B&W Htm4S center, and a pair of silly Dali bookshelves for surround.
And no, no external amplification.
But, as I said before, we usually watch at -30dB setting.. If I watch by myself, I don't need -20dB, even. My AVR doesn't get drained for power.
no clipping on the pre-out..
and this was what my criticism is based on.
He measured at +2 dB and saw that it was required to get 2V output.
He then continued to meaure at +2dB, despite seeing that 0dB setting was perfectly fine for 1.4V output volume (which is, according to Denon, perfectly fine for any external amplifier, but doesn't matter at all when using internal amplification!!!)
I am pissed that Amir refused to measure different volume settings after seeing that the amplifier locked up.. he never once thought about using 0dB for amplifier tests..
Fronturile B&W Nautilus 803 (89dB/1W/1m cu podea cu impedanță foarte scăzută), centrul B&W Htm4S și o pereche de rafturi Dali stupide pentru surround.
Și nu, nici o amplificare externă.
Dar, așa cum am spus mai devreme, de obicei ne uităm la setarea -30dB.. Dacă mă uit singur, nu am nevoie de -20dB, chiar. AVR-ul meu nu se scurge pentru putere.
Ce amplificator ai?... Nu mi-am amintit.
What amplifier do you have?......I didn't remember.
You can talk about something (like it) and have something else. Are you happy with it?
I am very happy with mine.
Never had any issues whatsoever, super easy to stream Tidal from my phone.
Only need the one remote (from my Nvidia Shield) to power tv and receiver..
the only gripe I have is that they refused to release the bass management for the 505.. there was no rational reasoning behind that decision.
But Denon users didn't even get basic Dirac live, so I guess I shouldn't complain.. I was a happy Denon user for a long time (2808, iirc, before I had a Pioneer SC-LX57 or whatever its name was for 7 or so years straight before getting this here 505 beauty for 700 USD after shipping and taxes and everything..
One day, I'll have my own dedicated room, then I'll get an Atmos setup with 4-8 subwoofers..
Until then, which may well be 10 years away, I'm happy with my Pioneer.
I'm very happy with it too! At least since I connected the subwoofer and the external amplifier (to complete the rest of the 7.1.4 channels), I calibrated the Pioneer again and I can no longer hear the background noise (the dwarf on my brain is gone).
The firmware that allowed the RZ50 and DRX 5.4 to get DLBM/DLBC was released Fall 2024. The first I heard that Pioneer was pulling it's license from the PAC group was Summer 2024. I would imagine the loss of the Pioneer licensing had a lot to do with a stoppage in Dirac cooperation/partnership that prevented the 505 from getting further Dirac development.
We know that Amir most likely won't change his testing methodology and the future RZ51, 7200, etc. most likely will undergo the same testing as before when they come out in '27/'28. There are plenty of other forums where you don't have to deal with what you don't prefer so perhaps a break from ASR is in order [said with all seriousness for sake of your mental health]?
