Pioneer VSX-LX505 AVR Review
Rate this AVR:
    Votes: 169 63.8%
    Votes: 46 17.4%
    Votes: 42 15.8%
    Votes: 8 3.0%
Amir, I'm unclear on precisely what set of conditions trigger the low output mode, perhaps you might clarify? From your original review it seems the AVR amps need to have gone into clipping first? Or do I have that wrong?
In other words from a different perspective, if we power up the AVR and then drive two channels of 120W into 8 Ohms per datasheet specs, i.e. not into clipping, then does the AVR revert to the low power output mode after a nominal 35 seconds? Or did it do it after some other time period that you observed?
Thanks
Amir's test of continuous output cause it to go into protection mode with an 8ohm test - so the examplar that Amir was testing would absolutely go into protection (low power mode) driving 120W into 8ohm after 35s.
I simply cannot believe that a manufacturer would put that onto the market - and that the other exemplar that Amirm tested (Onkyo RZ50) did not exhibit the same issue - hence I think that this particular unit has a fault of some kind. (or I am being naive)
Well its not clear to me from what has been written by Amir, which is why I asked Amir specifically. Can you point to specific text from him that makes it unambiguous?
I am also applying Occam's razor to the spec sheet and similarly find it highly unlikely that any engineering management, let alone corporate lawyers, would sign off on meeting an FTC spec of all things if the AVR didn't. The ramifications of a potential class action would be an appalling financial risk.
Same thing happened with these... so not a one off event specific to one model only;
JSmith
Amir please give me the last (I hope :)) answer. If I buy a Pioneer 505 and add a 3-channel Purify amplifier to the LCR and the internal amplifiers will only be used for 2x surround and 2x atmos and push it to the max, can the protection be activated? More precisely, does the protection monitor the performance of the internal preamplifiers and the real, small performance of the amplifiers used for surround and atmos?
I have the RZ50. Initially I powered the L/R and rear surrounds w/ external amps and at reference level did not experience any limiting. I now use 3 ch Buckeye Purifi for L/C/R and Buckeye 252 for rear surrounds and the AVR the heights so never experience limiting. No telling what would happen if one had difficult to drive L/C/R, used only internal amps and no subs-I would have to believe there would be issues including limiting and clipping.
What about the AccuEQ/Dirac stuff?
Wondering about the reference to the fan never turning on. I own two lx505's, both on the most recent firmware. Both consistently have the fans running low. Both are extremely well ventilated, one sits on a shelf by itself with nothing surrounding it on any side. Fans seem to come on at relatively low temperatures and honestly it's one of my biggest gripes with the units. I hate fan noise during quiet passages.
I run external amps at the moment but ran both units without amps for weeks. Fans come on with or without external amplification connected to the preouts. As well both units get pretty warm, not as warm as my Denon x3700h did, but they get noticeably hot/warm to the touch, even with the fan on or external amps connected. I'll pay more notice next time when the fans kick on and look at the ciuser interface to record the temps of each unit.
Just wondering if it's possible the refurbished unit in this test had some other issues perhaps no one is aware of as I have two lx505's that exhibit vastly different fan and thermal characteristics. Any chance the AVR is going into Nanny Mode because it's trying to turn on a faulty fan, can't, so kicks into some kind of protection?
I've had the laptop open and watched for the fans coming on and/or limiting several times now (most recently tonight for appx 3 hours) and I've never noted the fans coming on nor protection enabled. Maybe if I unhook all my external amps and use all the internal amps maybe I could get the fans to turn on and/or engage protection but I'm too lazy to unhook all that. Btw have the RZ50.
On a side note I follow the RZ50 thread on AVS forum and AFAIK no one has experienced the limiter engaging, even those who use all internal amps.
What do you mean? Do I use them/like them? If that's your question then yes I used AccuEQ in the past but not on this AVR-DL only and it's so much better to my ears-no comparison to AccuEQ.
Just curious how it played into your description. I've seen some reports you need to start with AccuEQ to proceed with DL. I'd hope DL is better than AccuEQ, tho.
That must be why class action lawsuits are so rare. Human nature to think smart expert can get away with it. I remember VW diesel scandal. How about Perdue Pharma disaster. Criminology expert in Idaho not doing too well.
How do you know if limiter engages?
I can't. I only reverse engineered the time constant and > 20 watt output. I am fairly confident the design also looks at other factors like temperature to also trigger limiting even if you don't hit the 35 second time limit. Fully profiling and reverse engineering of this black box would take a lot of work and analysis which I did not perform.
We don't review things based on your settings. We review things based on industry standards and demands of many listeners. So the notion that a manufacturer should cater to your modest needs with a footnote in the specs is non sequitur.
No one said or told you how to review.Just some of us that actually use the device in the real world can comment that this has never been reported/experienced in the real world in any of the dedicated online forums and are happy with it.Or is commenting that you don't agree with not allowed and subject to your petty attempts to insult people?I expected better of you/this place tbh.
i think there's a misunderstanding about what audio SCIENCE review is all about
its not a place where people are all that appreciative of so called 'real world experiences' because all that is is that its a single anecdote
ANY piece of equipment can work will for *some* people in *some* circumstances... there's literally no value to that kind of discussion, there's no way to test for it, there's no science behind it.
People seem to forget that even subjective audio reviews can be of limited value... hence the objectivists who go on about abx testing.
Its like saying I bought a Lamborghini Urus... it works fine dropping kids off at school and taking the shopping... that's real world use isn't it?
yeah but that's not the point. The emphasis is on power and torque and 0-60 and quarter miles and terminal velocity which is like you know, the graphs...
again, if a Urus SUV does 230hp per wheel but only for 35 secs and then it drops down to 20hp per wheel and then people say... "oh this works fine when I drive to work"... some owners would have to inject the copium and say 'this is fine'.
if I bought such a piece of equipment I'd have different thoughts but hey... if you're happy, you're happy, you dont have to try to convince people who wouldnt touch a $1,699 20w amp.
I don't listen all that loud (living in a condo) but my lx505 delivers plenty volume though my kef R3 roughly 4m away. I don't think I've gone louder than -20db and it has never shown volume drops...
"fine to perform in normal use cases" and "fails to deliver on the promised specs" are not mutual exclusive. Actually it is more common than you think.
No disagreement whatsoever there. I do wonder what panther amir would have given if pioneer wrote 20wpc on the spec sheet
I also wonder if it would be possible to get a statement from pioneer?
apparently some folks would still buy this if it said "20w"
i mean there's all kinds of folks out there
also given that pioneer seem to have at least 3 amps that do this same thing i guess the response from them will be "_______________"
No. Only used DL on the RZ50. One can calibrate using either and switch between them if one wants. One does not need to use AccuEQ first. Many have difficulty using DL hence comments about using the much simpler (but less effective) AccuEQ.
Actually - when you have a "population" of anecdotes, that align - that is a scientific and measurable approach - it is how the Harman curves were developed... a bunch of subjective anecdotes!
Yes a single subjective data point, is not meaningful, but a forum full of anecdotes which display a trend - that is indeed meaningful.
What that meaning is - is a topic requiring further investigation - but yes you can measure it, and then, like any measurement, you need to determine what exactly it implies/means.
On one side we have amirm with his very well regarded engineering tests on a lab bench, on the other side we have a large community of owners, that have not experienced the issue that Amir has measured, in actual live use, in the field.
Another important data point, is that this behaviour (on the lab test bench) has been consistent across 3 generations of AVR's and across two tiers (lower and upper, LX30x and LX50x/RZ50)
As has been Onkyo/Pioneer/Integra's practice over many years, many of the main circuit boards (including amps, DSP, DAC's and HDMI boards) are shared within the tiers... and the overall design is shared between the tiers as well.
Clearly, this design DOES power limit under specific stress conditions - clearly most of us consider the thresholds for that limiting to be far too restrictive to meet our expectations of what an amp in this price bracket should be capable of.
However, having said all that - we have a massive number of happy consumers of these products with no (or almost no?) reports of limiting in the field, in real live use.
At this stage, the tests done by Amirm are insufficient to make real conclusions about the parameters that trigger the nanny circuit.
It is also worthy of note, that most buyers of this family of AVR's who are aware that their speakers are "difficult"/demanding of the amps, run external amps, as they do not believe these AVR's to be sufficiently robust to handle such speakers. (I am one of these)
And therefore to some degree, in field use of these AVR's users are self selecting out those setups most likely to trigger protection circuits.
This is definitely a question that should be raised with Onkyo/Integra/Pioneer - Voxx-Sharp/PAC - as the answer would only be available from the design engineers... (who may be gagged by marketing...)
i'm not sure what else you need to convince yourselves that this unit does not meet the requirements of many people here.... more anecdotes?
there's at least three Pioneer amps here that does the same thing.
I dont know what else you need? what hi-fi and steve guttenberg to give the thumbs down?
i mean you really want to die on this hill... for Pioneer???
would you give the same courtesy to audi when the numbers came out?
I mean I literally love every Audi I've ever driven... there's an annecdote there but that doesnt go again what the numbers say...
