I have a client who had me go over his Pioneer SX-950, he had it done- quite thoroughly, by a service tech prior - he told me it cuts out, randomly. Not volume related. Comes back after 20 seconds or so. Opened the unit up, the original tech did not change the relay in the power amp side - I got a new relay, better than the original. Tested everything, DC bias fine, Rail voltage fine. Ran the amp in my place for about 2 days straight, 2 speakers, 4 speakers - no issues. Client picks it up, brings it home. Fine for about 2 days - guess what, cuts out. So I go to the clients house - and just out of curiosity I measure his outlets. 124.8 to 125.0 Volts. That's exactly where about these older receivers run into issues, especially with the fault circuit.
As I find out, the Service providers don't spring into action unless it's above or at 126 Volt. Neither will the HOA. So there's that. Now, I disconnected the Pre- from the Power-, and loaned him a Fosi Audio V3, and that works just fine. However the client wants to modify the Receiver, so it's perfectly capable to run in his house - on the AC he gets. I suggested other options - but that's what he wants.
So if anybody has re-worked an older Receivers Power supply for issues like that - I would really appreciate any input.
Cheers and thanks
Cheers and thanks
