Pioneer PD-D9 Review (CD/SACD Player)
Rate this CD Player
  • Terrible (*)
    Votes: 0 0.0%
  • Mediocre (**)
    Votes: 5 8.5%
  • Good (***)
    Votes: 26 44.1%
  • Excellent (****)
    Votes: 28 47.5%
NTTY
Reviewer
Switzerland
Hello Everyone,
This is a review and measurements of the Pioneer PD-D9-J CD/SACD Player and Transport.
This is my second review of a Pioneer CD/SACD Player, after the more recent PD-30 which did pretty well.
Released in 2007at roughly $1200, it was an expensive CD/SACD player, and the top of what Pioneer had to offer. I did not know this player and I was surprised by its weight at 11kg (24.2lbs). It’s much better looking IRL than on any pictures I saw. The front face is made of two very well-adjusted aluminium parts. A procedure is provided in the service manual (one of the best I’ve read) about how to adjust them, should it be required.
So it reads the CD and SACD, that's all, no digital input to benefit from the internal DAC with other external sources:
As opposed to the Yamaha CD-S2000 that I recently reviewed, no XLR outputs here.
There were two main reasons for me to get interested by this CD/SACD Player:
  • It hosts 2 stereo Wolfson DACs operated in mono mode, the WM8741, and that is one DAC I wanted to get to know more. It can decode DSD directly or convert to PCM beforehand.
  • It offers the “LEGATO LINK” from Pioneer which is their (Slow) Oversampling filter offer, similar to Denon with their AL24/AL32.
The advantage, with the Pioneer, is that the LEGATO filter can be deactivated, and I thought it would revert to one of the 5 filters available in the Wolfson DAC. But no, as per my measurements, it’s obviously a second filter from Pioneer. More on that when we’ll go into the measurements.
Wolfson did really great DACs at the time, and I was impatient to test this one, even if the THD+N @0dBFS was “only” -100dB per specs. The SNR, even with A weighted, was a very high 128dB (fs=48kHz) and so that meant a very silent DAC. I wanted to verify that.
This is the inside of it:
The power board:
The conversion board:
On a user experience point of view, not much to say, except that the drive is reactive, a little more than the Yamaha CD-S2000, and FFW/REW are convenient to use (2x, 4x, 8x). I was very surprised to hear the same faint noise when it spins a disc, as I heard with the Yamaha CD-S2000. Maybe they share the same drive, I did not check. I could not hear anything from beyond 1 foot (30cm), so I guess it's ok.
Note that there is a "Pure Direct" mode which has no impact on measurements and deactivates the digital outputs. So that Marketing advantage has the sole effect to reduce the functionalities of this Player for the end-user…
Pioneer PD-D9 - Measurements (CD Audio)
All measurements performed with an E1DA Cosmos ADCiso (grade 0), and the Cosmos Scaler (100kohms from unbalanced input) for analog outputs, and a Motu UltraLite Mk5 for digital.
I am now consistent with my specific measurements for CD Players, as I described them in the post “More than we hear”, and as I reported them for the Onkyo C-733 review. Over time, this will help comparing the devices I reviewed.
I measured 1.897Vrms (0.46dB below 2Vrms) output from RCA. The channel imbalance was a low 0.03dB. Phase showed a roll off at 20kHz of 20° with LEGATO ON and 2° without
As usual, let's start with my standard 999.91Hz sine @0dBFS (without dither) from the Test CD (RCA out):
We get the documented THD of the Wolfson, at full scale, not taking noise into account. The calculated SNR with this 0dBFS test tone is a comfortable 98dB, which again confirm we meet the specs of the Wolfson DAC,
Let’s have a look of the same at -6dBFS:
H3 is on the rise, but still reasonably low and the SNR has improved a little meaning the DAC is silent enough to resolve CDA without issue (hopefully).
I guess you saw a very silent player, but let’s zoom on that, for fun:
Any potential power supply leakage is buried way below in the noise floor, as we don’t see anything here despite the lengthy FFT that I use for this measurement (512k), and that means there’s nothing to hear on that perspective at least down to 24bits equivalent resolution!
Next is the bandwidth, first with LEGATO OFF:
We get a near flat bandwidth, with some ringing, and I measured this to be roughly 300 times higher that the typical documented passband ripple of the Wolfson DAC oversampling filter(s) at 44.1kHz sampling rate. This is of no hearing consequences, so only for knowledge. That, with other measurements, mean to me that the Wolfson internal filters are not used at all, and Pioneer relies on two external filters, one of which is the LEGATO, and it impacts the bandwidth, as shown below:
It starts rolling off before 10kHz and the attenuation is off the graph at 20kHz, per my standard zoom.
I’ll add one more graph soon, but I saw -3.56dB attenuation at 20kHz, meaning this is a very slow filter that will let a lot of artifacts of the conversion being created beyond fs/2 (22.05kHz).
Pioneer documents the LEGATO filter as per the below (from the User Manual):
For as great as CDs sound, the digital recording process clips off important musical shadings and nuances above 20 kHz. These signals contain important clues about musical texture and shape that define a live musical event. Pioneer’s Legato Link Pro Conversion system uses psychoacoustic processing to restore missing high frequency dynamics to fully recapture all the shading and detail of the original performance.
And this is BS, sorry Pioneer. The reality is that the LEGATO filter will let a lot of aliases of the conversion being created beyond 20kHz, like I explained with the SMSL PL200 here, which offers a non-oversampling filter. These do not include “important clues” because they are not related to any potential missed musical content past 22kHz. They are copy/paste of frequencies below 22.05kHz, mirrored around fs/2, and replicated, all due to the voluntary weakness of the filter. Who can say that a Sine tone at 10kHz, replicated at 34.10kHz has any musical content and therefore interest?
So, the LEGATO is a slow filter and let’s have a look at it with a wider bandwidth:
You can see, from the white noise, a significant rebound beyond 44.1kHz. I overlaid that, as usual, with the IMD AES dual tones (18kHz&20kHz 1:1). This view is interesting as it shows that not only there’s a mirror copy of 18khz&20kHz tones at respectively 26.1kHz&24.1kHz, but there is also a subsequent full copy paste of everything from 20Hz to 44.1kHz from 44.1kHz to 88.2Khz!
This is why you can see copies of our dual tones repeating again, and logically, at 62.1kHz&64.1kHz and 68.2kHz&70.2kHz. All of that is not music, just garbage created by the 0-hold function that all DACs generate, and that we should be filtering… or not…
Let’s quickly compare the same view with the other filter of this Pioneer, which is a sharp one:
And voilà, this time the artifacts are very well suppressed as they should be (my point of view), and what’s left is at -90dB, or below.
From my measurements, this (Sharp) filter has the below characteristics (including analogue filter effect, of course):
  • Passband : -0.1dB
  • Passband ripple: ±0.02dB
  • Stopband : 0.551fs (24.3kHz)
  • Stopband Attenuation : -93.7dB
  • Attenuation at fs/2 : -14.3dB
Since the attenuation at fs/2 that I measured does not correspond to any of the 5 filters choice offered by the Wolfson DAC, I guess the Pioneer uses another one.
Final note: I think I talked enough about all of this, and every time I’m faced with a slow filter that is sold as a Marketing argument of better sounding, I can’t resist. Because creating garbage out of the audio band is not the purpose of a D/A converter. Also here I saw a small phase deviation with LEGATO ON (20° at 20kHz) so, I’d recommend sticking to the non-LEGATO filter which offers decent performances. But at least the customer has the choice of filter selection, which I appreciate.
Oh, I almost forgot to show what happens at a higher frequencies, since I’ve been showing the same for few reviews recently:
The noise shaper of the Wolfson Delta-Sigma modulator rejects noise beyond 100kHz and that is very good, modern I’d say. The blue line shows that the Stopband frequency of the LEGATO filter is at 82kHz, too late if you ask me. Ok, enough now and let’s move on.
Let's have a look at the multitone test that a lot of you like very much:
The trace is very good. The Pioneer is distortion free for roughly 18bits which is good. Note that both oversampling filters have no impact on that performance, and it’s good to know that there’s no intermodulation distortion coming back into the audio band from the slow LEGATO filter.
The jitter test shows a happy player:
This is an overlay of the two channels. The trace is perfect on jitter perspective, and we only see some very level random noise at the foot of the fundamental. That is to be ignored because most of the time, that noise floor spreads over the full bandwidth, meaning it is higher from 20Hz to 20kHz. Have a look at the results of the excellent Sony CDP-X333ES, for instance.
Started with the Teac VRDS-20 review, and on your request + support to get it done (more here), I'm adding now an "intersample-overs" test which intends to identify the behavior of the digital filtering and DAC when it come to process near clipping signals. Because of the oversampling, there might be interpolated data that go above 0dBFS and would saturate (clip) the DAC and therefore the output. And this effect shows through distorsion (THD+N measurement up to 96kHz):
Intersample-overs tests
Bandwidth of the THD+N measurements is 20Hz - 96kHz
5512.5 Hz sine,
Peak = +0.69dBFS
7350 Hz sine,
Peak = +1.25dBFS
11025 Hz sine,
Peak = +3.0dBFS
Teac VRDS-20-30.7dB-26.6dB-17.6dB
Yamaha CD-1-84.6dB-84.9dB-78.1dB
Denon DCD-900NE-34.2dB-27.1dB-19.1dB
Denon DCD-SA1-33.6dB-27.6dB-18.3dB
Onkyo C-733-88.3dB-40.4dB-21.2dB
Denon DCD-3560-30.2dB-24.7dB-17.4dB
Myryad Z210-70.6dB (noise dominated)-71.1dB (noise dominated)-29.4dB (H3 dominated)
Sony CDP-X333ES
-30.5dB-24.8dB-16.3dB
BARCO-EMT 982-32.7dB-24.5dB-16.3dB
TASCAM CD-200-73.5dB-36.3dB-19.7dB
Sony CDP-597-30.4dB-24.7dB-16.5dB
SMSL PL100-53.1dB-31dB-19.1dB
SMSL PL200-94.8dB-97dB-39.5dB
OPPO BDP-95-39dB-28.8dB-19.2dB
Yamaha CD-S2000-29.7dB-24.1dB-16.6dB
Pioneer PD-D9 – LEGATO OFF-30.7dB-25.1dB-18.0dB
Pioneer PD-D9 – LEGATO ON-29.7dB-24.0dB-15.9dB
Basically, the oversampling interpolator does not have any headroom to prevent intersample overs, as many others. And note that the LEGATO filter decreases the scores by 1 to 2dB.
Let's continue with the good old 3DC measurement that Stereophile was often using as a proof of low noise DAC. It is from an undithered 997Hz sine at -90.31dBFS. With 16bits, the signal should appear (on a scope) as the 3DC levels of the smallest symmetrical sign magnitude digital signal:
This is a very good trace as we see nearly no added noise, and that confirms the other measurements, fact that the Pioneer has no issue to fully resolve the CDA.
Other measurements (not shown):
  • IMD AES-17 DFD "Analog" (18kHz & 20kHz 1:1) : -94.1dB
  • IMD AES-17 DFD "Digital" (17'987Hz & 19'997Hz 1:1) : -95.4dB
  • IMD AES-17 MD (41Hz & 7993Hz 4:1): -88.4dB
  • IMD DIN (250Hz & 8kHz 4:1) : -83.8dB
  • IMD CCIF (19kHz & 20kHz 1:1) : -86.2dB
  • IMD SMPTE (60Hz & 7kHz 1:4) : -84.9dB
  • IMD TDFD Bass (41Hz & 89Hz 1:1) : -106.7dB
  • IMD TDFD (13'58Hz & 19841Hz 1:1) : -104.4dB
  • Dynamic Range (without dither @-60dBFS) : 98.8dB unweighted. 97.9dB CCIR2k weighted, 101.6dBA
  • Crosstalk: 100Hz (-123dB), 1kHz (-123dB), 10kHz (-105dB)
  • Pitch Error : 19'996.70Hz (19'997Hz requested) ie -15ppm
  • Gapless playback : Yes
  • De-emphasis compliance (deviation at 11khz) : Yes (0.0dB)
The IMD scores are good but they are often better.
The Dynamic range is the best that can be measured (unweighted) with the Audio CD..
Crosstalk is very low all the way through to 20kHz.
Pitch error is good for audio.
Last and not least, I like to run a THD vs Frequency sweep at -12dBFS as it shows how the conversion has evolved over time. I am currently using the beta version of REW and I discovered that this sweep gives better and more reliable results than before. I overlaid the results with the best in class SMSL PL200:
At this level (-12dBFS), the H3 is dominating, and it’s the one downgrading the reported performances on this test. It is still very good and will remain hidden into musical content, but several other DACs do better.
As I did with the Sony CDP-597, I add a "max DAC resolution" measurement test. It is performed from a 999.91Hz sine @-12dBFS with shape dither (from Audacity). I restrict the THD+N span to 20Hz - 6kHz in REW not to account for the noise of the shape dither beyond 6kHz. I take the calculated ENOB and simply add 2bits to it (due to the -12dB attenuation, as 1bits=6dB). The potential maximum, when calculated from the digital WAV file, is 18.7bits under this test. A "transparent" DAC should achieve 18.7bits, ie 100% in this test.
Here are the results of the Pioneer compared to others:
CD Player model or DACCalculated ENOB (999.91Hz sine @-12dBFS with shape dither, THD+N span = 20Hz - 6kHz)Percentage of max resolution achieved (higher is better)
OPPO BDP-9518.7bits100%
SMSL PL-20018.7bits100%
SMSL PS-200 (from CD player)18.6bits99.47%
Pioneer BDP-LX5818.5bits98.93%
Denon DCD-900NE18.5bits98.93%
Yamaha CD-S200018.4bits98.40%
Onkyo C-73318bits96.26%
SMSL PL15018bits96.26%
SMSL PL10017.9bits95.72%
Pioneer PD-D917.7bits94.65%
Sony CDP-59717.5bits93.58%
Onkyo DX-735517.3bits92.51%
Denon DCD-356017.2bits91.98%
Yamaha CD-S30316.8bits89.84%
Revox B-226S16.8bits89.94%
Accuphase DP-7016.6bits88.77%
Sony CDP-337ESD16.6bits88.77%
Teac VRDS-25x16.5bits88.24%
Marantz CD-7314.9bits79.68%
One more time the Pioneer is let down by the higher than wanted H3 at this level (-12dBFS). As a matter of facts, the distortion, goes much lower at -16dBFS and below. But since the above test, invention of mine, is set at -12dBFS, too bad for the Pioneer.
To complement what I said, I’d like to show you that distortion and noise are very well managed below -16dBFS. The below is my standard 999.91Hz @-20dBFS with shape dither. I overlaid the output of the Pioneer with the one of the OPPO BFP-95, as a reference player using very well implemented ESS DAC:
You can appreciate that the two traces are very close, and at this level of quality, we can consider they are the same. All that means well done to Wolfson and Pioneer!
Pioneer PD-D9 - Testing the drive
Before going to SACD specific measurements, let me talk about the drive tracking capabilities, since these tests are performed from a CD Audio.
What would be good measurements if the drive would not properly read a slightly scratched CD, or one that was created at the limits of the norm? The below tests reply to these questions.
Here are the results:
Test typeTechnical testResults
Variation of linear cutting velocityFrom 1.20m/s to 1.40m/sPass
Variation of track pitchFrom 1.5µm to 1.7µmPass
Combined variations of track pitch and velocityFrom 1.20m/s & 1.5µm to 1.40m/s & 1.7µmPass
HF detection (asymmetry pitch/flat ratio)Variation from 2% to 18%Pass
Dropouts resistanceFrom 0.05mm (0.038ms) to 4mm (3.080ms)Pass
Combined dropouts and smallest pitchFrom 1.5µm & 1mm to 1.5µm & 2.4mmPass
Successive dropoutsFrom 2x0.1mm to 2x3mmPass
One more best-in-class drive that passes all tests, yeah! I saw the servo interpolating as soon as with 2mm dropouts but I could not hear any negative impact.
Pioneer PD-D9 - Digital Optical Output (from Audio CD)
Ok, so let's verify if the Pioneer outputs a "perfect" digital stream, in case you think or want to verify an external DAC can do better. This is from my standard 999.91Hz @0dBFS file:
This is what is in the original WAV file.
Same with the standard Stereophile 3DC test:
No modifications of the signal to be seen here.
My ultimate proof of "perfect" digital output is when I reuse the intersample overs test at 5512.50Hz, with a phase shift of 67.5°, like I did for the TASCAM CD-200 review. This signal generates an overshoot of +0.69dB and so if the signal would be modified before being sent, it would show either a reduction of amplitude or we'd see some sort of saturation/increase noise/distortion. So here we go:
We get the 0.69dBFS overshot and no distortion. This is the same as the original WAV file, hence "bit perfect" output.
Partial conclusion (As a CD Player)
The Pioneer PD-D9 is a very precise CD player, with very low noise and distortion. The LEGATO filter is funny, and not enforced, which is good.
I was expecting very good performances from the Wolfson DACs used in mono mode, and I was not disappointed. The H3 prevented it from reaching the top in few cases, but the level of distortion remained below audible concerns.
We also get a really “perfect transport” when it comes to digital output as well as ability to read scratched silver discs. The look and build quality sets it apart, if you’re still into buying that type of wide footprint device.
To be continued with SACD tests...
Pioneer PD-D9 Measurements (SACD)
Unfortunately, I can't create an SACD test disc, so I used the one from Denon. This the test 1kHz @-16dBSACD (equal to -16dBFS with this test SACD):
The above result is very good with minimum distortion. We see the small leak from the PS at 50Hz (-120dBr), to low to be heard. And this result is nearly identical to that of the Yamaha CD-S2000 that I reviewed last week, meaning the quality of the test SACD is lower than the resolution of these SACD players.
The Wolfson DAC of the Pioneer can process DSD signal directly, as the below shows:
The LEGATO filter can't be activated with SACD. The ultrasonic profile of the noise shaping demonstrates no modification of the DSD digital stream before conversion.
As I did with the Yamaha, I thought it'd be interesting to show you the difference between SADC and CD Audio, in how they manage ultrasonic noise. The below is a 1kHz test tone at -16dBFS from SACD and CDA with rectangle dither (0.5bit):
If, in audio band, the CDA is behind with its elevated noise floor, when it comes to ultrasonic noise, I don't need to tell you about who's the winner... Of course, the orange trace is without the LEGATO filter.
Final Conclusion
One more SACD/CD Player that I liked a lot!
I could not find any obvious faults, certainly nothing problematic when it comes to enjoy music.
The SACD performances I measured are at the limits of the Denon Test SACD that I use. So I can only recommend this Pioneer is you get lucky to cross one at reasonable price!
I hope you enjoyed this review!
I almost bought this one based on design but some reviewers complain that it's loud mechanically.. is that your impression as well?
Loud, no. You need to be close to it and in a silent environment (ie no music) to hear the faint noise I mentioned. Past 1 foot, I can’t hear it.
Thanks @NTTY is there a difference in noise shaping between this and MQA?just curious. it seems they do the same.
I don’t know much MQA, but it is a very different concept. It recovers some digital data that have been somehow compressed into a smaller file. Once the data is recovered, it will be processed by the DAC for conversion and that is when noise shaping is applied by the delta-sigma modulator. Maybe MQA degrades the original file in their folding process, or creates distortion and noise when not decoded by an MQA compatible processor. I don’t know, but it would be of a different nature, I suppose.
I voted mediocre because it can't output multichannel. This SACD player only outputs in 2 channels which IMO defeats the purpose of SACD as a source for multichannel music. The improvements in frequency response and S/N ratio are inaudible vs. any reasonable CD player. It's only virtue is its high quality build vs. most CD players and playing the rare SACD discs that won't play on regular players.
From what I can tell this SACD player only outputs in 2 channels which IMO defeats the purpose of SACD as a source for multichannel music. The improvements in frequency response and S/N ratio are inaudible vs. any reasonable CD player.
I think the same. I never understood why high-end SACD players only have stereo outputs.
I attended some multichannel presentations back in the day when SACD was new. My personal impression was, very nice and immersive, but it was like watching a movie with the picture missing. So, for music I preferred to stick with stereo.
When this player was discontinued, I tried to find one of the last items but wasn't successful. It seems I missed a good deal. :(
It's funny, despite having enjoyed stereo reproduction since the late 70s, I actually find stereo reproduction of music very uninvolving. I much prefer some multichannel presentation even if it is less realistic. The immersive soundfield is just so much more enjoyable.
Final Conclusion
Nice review.
This gem is also in my collection.
I really like that you're testing all these older CD players. I keep hoping you'll test the cheap and cheerful Sony BDP-BX57 Blu-Ray player. I own two, one in the living room for video, one in my bedroom for sound. It happens to be SACD capable so I can play the small number of single-layer SACDs in my collection. It can also play DVDs, including DVD-A on the regular DVD layer. And it also plays back Blu-Ray audio. My experience is that the stereo analog output doesn't sound as good as using the digital out though my Topping E30 DAC, but the sound through my DAC is excellent. I got both players through thrift stores, one for $8, the other for $20. As a basic transport, if fulfills all my needs.
I listen to multichannel stereo (more than two channels) classical and jazz recordings, where available, and the faithfulness to live sound is much better than the plain 2.0 stereo versions of the same programs.
And I share @OsoSolitario's bewilderment about the fact that most of the higher end SA-CD players were 2.0 only.
But there have been some manufacturers that have done their homework to support multichannel SA-CD in the past: Philips (the first Philips SA-CD player was a multichannel DVD-V/SA-CD player: the SACD-1000), Sony (with the glorious SCD-XA777ES and SCD-XA9000ES and the little brothers SCD-XA333ES and SCD-XA3000ES as well as the following SCD-XA1200ES and more humble players), Marantz (SA-12S1, SA8260) and some smaller boutique manufacturers that deserved to be praised for that: Linn (Akurate CD) and Esoteric (SA-60). Unfortunately, none of these manufacturers has persisted in its effort, Sony being the longest supporter of multichannel audio-only SA-CD players.
The backward-looking nature of most of the Hi-fi sellers and reviewers is undoubtedly responsible for this state of affairs.
Hi Florent,
Another great review from a great SACD player. This Pioneer initially only interested me for its looks and DACs, but your measurements confirm that my preconceptions weren't imaginary.
The market was not demanding, obviously. Maybe some studios were reluctant to master with 6 channels and not being paid 3 times more? :)
I guess more than resellers, audiophiles disregarded multichannel as low value devices and probably did not trust that quality could be found in masters. I don’t know.
I think more than two speakers is way too intrusive so I never went multichannel.
To me an SACD player is the opportunity to test a good CD player :)
And for those wanting a perfect SACD multichannel player, there is the OPPO BDP-95 :cool:
Thanks!
Seems to be unobtainable in my area (BDP-S570 too) :eek:
That's too bad—Ebay lists 40 from $20 to $85.
