Pioneer BDR-X13J-S
Erogen
I need to transfer my CD collection to my computer's hard drive.
I read that this drive allows for error-free copying of "Copy Controlled" CDs.
Does this drive support that?
The drive features PureRead 4+ (and RealTime PureRead).
Does it work?
This model is currently very expensive.
What other drive allows for a perfect copy of a Copy-Controlled CD?
Copy control? Was this the lame attempt back in the day, every kid could "kill" by holding the shift key during read?
Anyway, I've ripped thousands of my CDs, and never had a problem with "copy controlled CD" or such.
OK, googled it, a long dead "DRM"
I would try the old trick: disable autorun if enabled, and then try ripping (e.g. with foobar2000) with AccurateRip enabled. Should work.
Unfortunately, not every optical drive allows for the error-free copying of "Copy Controlled" music CDs—a copy-protection measure used in the early 2000s.
While it is possible to create a copy using "burst mode," such a copy will not be error-free; only "secure mode" enables the creation of an error-free copy.
Unfortunately, "secure mode" does not allow for the copying of "Copy Controlled" discs.
In my case it was the opposite. A Copy Control CD could be copied on my PC but not played by my semipro CD recorder.
