svart-hvitt
- Joined
- Aug 31, 2017
- Messages
- 2,375
- Likes
- 1,253
- Thread Starter
- #41
Ok, I opened this thread not just to discuss pros and cons of vinyl playback even if such a discussion is entertaining (an opinion-loaded!) per se. However, a technical discussion on vinyl playback within its limitations is perhaps more interesting; it begs the question how far you can take vinyl playback in terms of technical excellence. Do you all see the point of this distinction?
So let's take a look at the SP-10R specifications with its stated SNR of 92 dB. If you intend to keep the noise-level in your playback chain at 92 dB, it means that your phono preamp and amps need to sport better specs than 92 dB, right? The problem is, phono preamps with SNR of 92 dB don't exist. The top Clearaudio preamp (over $15k) has an SNR of "only" 90 dB. Maybe this box (QES Labs is popular among mastering engineers with deep pockets) will keep up with the new Panasonic turntable drive: http://www.qeslabs.com/e_phono_preamp.asp or maybe this one https://www.mil-media.com/LOCi.html .
In other words: Is the SP-10R a game changer because it will expose the flaws of existing vinyl gear? Just think about it; you need to pay over $10-15k for a phono preamp in order to match the noise floor of the SP-10R. It's crazy, and it shows that vinyl in 2017 is a cottage industry of amateurs, sort of time-capsuled in the 1970s. So when a billion dollar (or yen...) company reenters the vinyl space, using 2010s technology, it makes other manufacturers of vinyl gear redundant from a technical point of view (from an aesthetic point of view I think the SP-10R will look great as well, but that's just an opinion and not a fact).
In other words: What is the lowest attainable noise floor in vinyl playback from a technical perspective? Has the SP-10R moved the old limits of vinyl playback noise floor?
