Considering I have read about the Pin 1 problem I can't manage to turn the understanding into a solution. I am aware that the Hypex NC modules have the ground from the module to the male clip on the XLR, while Pin 1 is connected to Chassis ground. Does this now mean that the XLR cable coming into the Hypex Amplifier doesn't need to be altered?
Now, for other amplifiers that do not have a connection based on the new standard (AES48 not that I can say I fully comprehend the schematic) do I change the XLR cable going into the amp or is it better to change the amplifier channels wires going into the XLR socket inside the amp? If its changing the wiring of the XLR socket then I can do the same as the Hypex module. But if its the XLR cable coming into the amplifier can someone tell me what needs to be changed?
And lastly just so I understand the whole topic better. When articles mention shield needs to be wired to chassis ground rather than Signal ground I get the shield its the part(wire) that wraps around the XLR cable but what is chassis ground compared to signal ground? I am guessing signal ground is the Pin 1 if that is so then what is chassis ground?
