WDeranged
- Joined
- Apr 8, 2022
- Messages
- 160
- Likes
- 138
A lot depends on the title.
I ran an LP mastering operation for about 20 years. What most people don't know is that a lacquer cut, if the cutter stylus is properly set up (correct angle, which varies from stylus to stylus, cutter depth, stylus temperature and so on) properly, it can cut a groove that is essentially dead silent. Play it, and literally you will wonder if the system is turned on or not until the music plays.
We did a few projects thru QRP. They found that by damping the pressing machines so they were more still while the vinyl was cooling caused a much lower surface noise. I had to talk to Chad Kassem directly (I"ve known him for over 30 years) to allow us to do our customer's limited run of 500 copies. The tests we got back were so quiet that just like the lacquers the surfaces were so quiet I was wondering if the system was on the right input when the music started.
Our source for the project was a digital file. You're not going to see those noise floors on larger runs with old analog sources.
I remember hearing Bernie Grundman say that vinyl has no noise floor and I thought wtf is he saying. I wonder if this is what he was talking about.
