Phono Cartridge Response Measurement Script
Thanks but I need start of left sweep to start of right pilot, not start of pilot to start of pilot.
The seconds are shown in the plot.
That's fine - I'll just remove support for the record until/unless I'm able to get thorough timing info for it.
Some cool progress. Unified script that does "standard" plots and "compare" plots.
Nothing new about "standard" except the config file syntax.
Code:
  "plot_info": "Standard",
  "equip_info": "Arm -> Phonostage -> ADC",
  "author": "Plot Author",
  "files": [
    {"path": "VM745xML-STR100_30k-105pF.wav", "label": ""}
  "mode": "standard",
  "style": 4,
  "dimensions": ["fundamental", "crosstalk", "h2", "h3"],
  "extract_sweeps": true,
  "extract_channel": "both",
  "test_record": "STR100",
  "normalize": 1000,
  "normalize_mode": "relative",
  "start_f": null,
  "end_f": 20000,
  "smoothing": 0.5,
  "override_ylim": null,
  "riaa_mode": 0,
  "riaa_inverse": false,
  "str100": true,
  "xg7001": false,
  "plot_data_out": false,
  "log_level": "info"
"Compare" is using full sweep recordings, extracting the left channel sweeps from each, plotting only the fundamental, and showing 1-20kHz using a more aggressive data smoothing filter setting (the one I usually use for loading comparisons).
Code:
  "plot_info": "Compare",
  "files": [
    {"path": "VM745xML-STR100_30k-105pF.wav", "label": "30k"},
    {"path": "VM745xML-STR100_33k-105pF.wav", "label": "33k"},
    {"path": "VM745xML-STR100_38k-105pF.wav", "label": "38k"},
    {"path": "VM745xML-STR100_40k-105pF.wav", "label": "40k"}
  "mode": "compare",
  "style": 5,
  "dimensions": ["fundamental"],
  "extract_channel": "left",
  "normalize": 1000,
  "normalize_mode": "absolute",
  "start_f": 1000,
  "end_f": 20000,
  "smoothing": 0.02,
  "riaa_mode": 0,
  "str100": true,
  "xg7001": false,
  "log_level": "info"
Nevermind the legend placement. Will make it pretty later.
In other news, pending separate verification, but looks like some good progress on higher sample rate RIAA biquads:
Oh cool. Reminds me of when I tried to test for the accuracy of the filters. Mine are certainly not accurate but these do show the scale and how it would "affect" the results.
I'm testing my P-Mount cartridges and am seeing some of them, mostly the MCs, where the script seems to reference the plots to the L channel crosstalk rather than main signal, as seen below for the AT312HEP. What am I doing wrong?
I have had this happen many times, but with older versions of the script that required manually trimming the audio.
I seem to recall that it was caused by too much silence after the right channel sweep, but I can’t say with certainty.
Not sure why that would happen with the current version, though.
I've been manually trimming excess at beginning and end.
Here is a link to the file:
Why?
You've a pathological amount of HF noise in your recording. If I run a steep LPF @30kHz on the file it plots fine, or if I remove the clipping at the sweep start (your levels are too hot - think about what happens when inverse RIAA is applied) it also works fine.
I tried lowering the levels by 12dB and still have same issue. Tried all different modes...MCPrepre-MM, MCPrepre-Line, MM direct, and nothing worked. Seems it might be associated with the Soundblaster box.
ive gotten results like this when i try to run the sweep as a single file sometimes it works, sometimes i get stuff like this. i stopped trying to figure out what i was doing or what was going wrong and have continued to trim the files and run them independently. that's worked 100% of the time.
No just trim the ends, and run script with both files left and right , no auto extraction. That usually works for me. If my recording level is low or crosstalk too good and end not clear, The script seem to become confused
Hmm, what do you mean by "both files"? In the "advanced" section I see an option for a second file but it's not clear what will be done with it. I tried using trimmed L and R there but it gave a garbage output. I don't see any option to turn off auto extraction.
