Phono Cartridge Response Measurement Script
Sure. Lemme think through how to confirm it. I think it'd also require some extra filtering as 2x bass boost can easily push LF junk up beyond the fundamental.
Yes, I usually do an HP around 400 Hz on these sweeps, to clean it up.
Reactions: JP
Actually a good excuse to figure out Scott's EQ code, as I also want super accurate coefficients for 192kHz. I have them for full EQ, but not split like we need. Last time I tried I didn't get far.
No need IMO, but ok if possible. Next is to understand why Ortofon and CA-TRS1007 can display such different crosstalk, which I do not really have a definitive answer for. VTA/SRA?
Dunno. I haven't played much with either record. EDIT: while you're at it @Thomas_A see if you can find anything definitive on EQ for TRS-1005. The response looks much better without it.
It’s a pity LD or Yosh is not around here. Perhaps @Balle Clorin can help with some geometry and maths in the fun thread. I don’t really know where to start.
Indeed. I haven't seen LD around anywhere for several years now. I thought I saw Yosh post somewhere not too long ago, but he hasn't been that active for a long time.
I do not have TRS1005 or any of the JVC records, so really no idea about it. No EQ above looks better, but which cartridge is it? I would guess an AT.
Pioneer PC-1000II.
It's more of a research project than an experimental one. Most test records are cut with bass roll-off and shelf because 1) on most lathes you have to modify the electronics to disable it and 2) if there's content there you have to have it*. On TRS-1005 they don't mention anything about the recording characteristic at all. The only clue is that they say the sweep tracks are meant to be recorded with a BK 2305, but don't mention anything about using the 4416.
Even more fun, I've seen plots done by cart manufacturers where some appear to not have EQ applied, and some do.
*Per the Ortofon/Flo record and Flo's comments, it'd seem that modification is required for a half-speed cut where treble emphasis was not applied. I may need to dust off the Neumann schematics.
My pal Claude and I refactored the sweep extraction function to use Hilbert Transform. The punchline is a bit more resilient on detection and around a 90% performance improvement for that process. Total processing time for STR 100 with sweep extraction on my machine is down to just a hair less than three seconds from around six seconds.
This is in SJPlot 18.5.0 or higher, which is already live for sjplot.com/online. The end of the first pilot tone must occur within the first 30 seconds of the file.
Sounds good. Still need to fix the script on my new M5 MacBook. If only Santa could give me some spare time.
MBP? I just picked up an M4 Air as they were on sale here. Was getting tired noise, heat, and thermal throttling on the old i7 I used in the music room. For light day-to-day workloads it's faster than my M1 Max MBP.
Yes, MBP M5. Errors with the numpy versions, no time to fix it yet.
I have been unable to analyze the STR100 data for the last couple days. I get this error:
attempt to get argmax of an empty sequence
And you get this error after the update I pushed 50 minutes ago?
Odd - never had an error with numpy. Only library issues I had was when the script was using librosa. Glad to have been able to dump that.
@Balle Clorin when you have a moment can you let me know the duration between the start of the left sweep to the start of the right pilot tone for DIN 45543? I can't find my layback.
