I don't understand.
I don't understand.
Then my guess is incorrect.I don't understand.
Sorry.Never did that.
Due to the hand built nature of cartridges (particularly the cantilever/suspension/needle) - and variation in inductance within production runs and between L/R - there can be quite substantive and definitely measurable differences between multiple samples even from the same production batch.It's helpful to understand the history. The exercise was kicked off to create a script which normalised measurements from different test LPs and presented the Frequency Response, AND distortion etc. on a single graph coupled with manually entered data about the cartridge, preamplifier, ADC, setup etc. In terms of repeatability, it's quite interesting to look at the multiple different graphs of the same cartridge (e.g. VM540) by different people.
The actual bass is not removed on a normal track, but it sums the channels , so in effect you see the shape of the elliptical derumble filter when only one channel has a signalOrtofon 2M Red, Parks Audio Waxwing, no Derumble
Same, with Derumble feature activated.
Yes, I assumed that it operated similarly to Douglas Self's Devinyliser and tonality is subjectively unchanged.The actual bass is not removed on a normal track, but it sums the channels , so in effect you see the shape of the elliptical derumble filter when only one channel has a signal
“Subjective reasons” could mean anything. Do you mean “the sound”?
Curious about your choice of XA variant of ART9, given that AT use a Shibata not MR profile on it, whereas the XI variant uses MR. It seems a big compromise to make on a principle of ‘air over iron’.
| Mode | Step-up Ratio | Reflected Load (47k/ratio²) | Divider Ratio | Output Voltage (Effective) | Gain (dB) incl. Divider Loss |
| 15:1 | 15× | 47k / 15² = 209 Ω | 209 / (209 + 12) = 0.946 | 0.2 mV × 15 × 0.946 = 2.84 mV | 20 × log(2.84 / 0.2) = 23 dB |
| 30:1 | 30× | 47k / 30² = 52 Ω | 52 / (52 + 12) = 0.813 | 0.2 mV × 30 × 0.813 = 4.88 mV | 20 × log(4.88 / 0.2) = 28 dB |
Thanks !It’s whatever the person puts. We ask that it be total capacitance. We prefer it to be appropriately measured.
