- Joined
- Nov 14, 2020
- Messages
- 412
- Likes
- 566
Any plan when this may happen?First is to integrate the automatic processing of the audio from a single input file that is based on @DrCWO's work.
I was going to suggest making all the bits that need changing into config file and command line options. That way nobody needs to edit the code unless they're doing some development.Also considering (but not researched much) options for platform agnostic GUI to make it more accessible. First is to integrate the automatic processing of the audio from a single input file that is based on @DrCWO's work.
Script appears to be working fine - not sure what you think is an issue.
These measurements were the first measurements. There was an error in the sound card configuration. The sound card drivers were restarted, subsequent measurements are now correct.Script is fine. His sweep recording is not. He keeps posting things like this and only corrects them when he is pestered enough. He's just sloppy with his ADC settings.
Wrong and right. If you have that tilt you recorded the sweep wrong.
View attachment 401593View attachment 401594
He deleted his original AT95E examples. Same exact thing. Again and again and again. Same excuses. Here's what he said when pressed. He knows better. He's just too lazy to double check his settings carefully and somehow forgot he just corrected the same exact mistake numerous times already. It's absurd at this point.
Everyone deserves a second chance.Oh - making multiple accounts now.
Different viewpoints I guess - possibly related to different approaches and expectations in Windows and linux. It wouldn't make a config file a requirement, just an option for anyone who wanted to use it. It wouldn't stop anyone editing the default values in the source either.It's partly due to my workflow - I leave the scripts open in the IDE and run them from there, so it's simpler to not have a config file. It's also simpler for some folks to not have multiple files which equates to less support issues.
I had a very similar experience with a German vendor. Took them at least a month to ship it out, although I did get it in the end.I got my partner to order me a second CA TRS-1007 for Christmas from a vendor in Germany, at considerable expense. My current copy is a bit warped and has ticks on two of the sweep tracks. Money was paid but the vendor never responded to any correspondence. A dispute was lodged with Paypal after a month and a tracking number was eventually forthcoming yesterday. Great I thought, all is not lost!
With the tracking number, the local postal service had it as stuck in the Melbourne airport sorting facility for two+ weeks. Unfortunately, their investigations now conclude that it is lost. Sigh, so one less TRS-1007 in circulation now.
I bought mine here and there were no issues at all:I had a very similar experience with a German vendor. Took them at least a month to ship it out, although I did get it in the end.
