How's the weather in Munich?
Yes, valid point, some cartridges do connect the shell to one of the ground pins. So, those would not do well wired for balanced.
Honestly, I question whether balanced wiring on a phono cartridge would yield any measurable benefit. Cartridge output is generated across a source impedance in the tens of ohms to low kohms, and typical cable runs are short (under 1.5 m) with capacitance in the 100–200 pF range — well below the threshold where common-mode noise pickup becomes significant at this signal level (a few mV).
Balanced (differential) wiring mainly earns its keep by rejecting common-mode noise induced over long cable runs or in electrically noisy environments; over a short, well-shielded run at line-level-adjacent impedances, there's little common-mode noise to reject in the first place, so I'd expect the improvement to be negligible at best.
Paul
