It takes less time to enumerate devices. But what is suspisious from your video - very low capture per s in 'scope. Du you have GPU acceleration on (under Look & feel).
The machine I'm running it on (in hardware, no VM) is an i7-4770K CPU @ 3.50GHz with 32G ram.
Video card is old (but still ok) - it's an NVIDIA Corporation GT218 [GeForce 210]
GPU acceleration is enabled. libglu1-mesa is installed.
I have some updates:
I tried the server version on Windows 7 (the machine is dual boot, Windows / Linux) and the server version worked ok with an external oscillator.
When I tried using the Phonalyser oscillator, I got an error: "The bench refused to open the output device, the device does not support this format".
But the FFT and 'scope worked fine. I did try other backends but the oscillator would not work.
So.. I switched back to Linux and tried the .dev package you published on Github - and that didn't work at all (no audio devices).
I then installed the server version on Linux - and both the ADC and DAC now work as expected.
I don't know what's different about the web version that it worked ok - I am puzzled!
But in any case - the server version works (and hopefully will still work after a reboot).
