Of course we usually play things back at whatever level we want to.
Perhaps that is a calibration level, so you can play back the recording at the same Sound Pressure Levels at which the microphone recorded the material. Maybe not a "recommended" level, just a "this is what it was" level.
Earlier in the life of this site, a member posted this thread:
https://audiosciencereview.com/foru...2-0-master-file-giveaway-for-asr-members.695/
His technique is to use the same recording setup for anyone ("classical" style, mainly) he is going to record in his studio.
At some point, he provided calibration information to the effect that the playback should be referenced so that a -20dBfs pink noise signal should produce 75dB SPL in the room (if I remember correctly). With that playback level, you aproximate in your room the same level as was presented to the microphones in his studio.
The exception was his recording of a drum solo, and he chose to reduce the recording levels by 20dB. I recalibrated for that (I forget exactly how, it might be in the thread), and the result was 116.9dB peaks in my room here (dangerously loud, and only played momentarily, and it did sound like there was a drumkit in the room with me).
Unfortunately, he disappeared after a while. I hope it wasn't my fault.
http://www.playclassics.com/about
http://www.musicstry.com/
