I own a pair of these, as the measurements show they are the only open-back I own that natively has good bass extension, which as an iPhone user is pretty important (no global EQ).
I don’t notice any obvious HF peaking with music, I just did a tone generator and ~ 5100Hz-5400Hz is indeed peaking, above that in frequency though the peaks/dips (and channel imbalances) I hear are different from the measurements here. But like I said, I don’t notice it with music.
I also don’t notice bass distortion, so either I’m not sensitive to it or Amir listens louder than I do (which has been a reoccurring theme); with the Apple dongle DAC (~30mW into 33ohm; ~109dB @ 1kHz if my math is correct), it gets more than loud enough for me (I’m usually 2 clicks from max), if that says anything. I just did a tone generater in the 250Hz-300Hz region and at higher levels I do hear that “Brr” that Amir talks about.
So yeah, FR & distortion measurements match my unit pretty closely, it’s just that I’m not sensitive to it with music, which I’ve known that I don’t have “golden ears” for a while, which I guess can be spun into a blessing
This headphone has had QC issues though, with channel imbalances or during the Black Friday sale some of the units even had the angled drivers put in incorrectly! Luckily it is user fixable. Using a sweep, mine does have imbalances, just not (audibly) to the degree as Amir’s unit, it mainly is the 400Hz-800Hz region where it pulls right, and around 5600Hz-5800Hz where it pulls left, and no large suck out around 9kHz in either channel.
The note about the pads is real, they collect hair and dust like nobody’s business. Clamping force is also a tad much.
___________
I’m waiting to see what high-end open-back headphone I could upgrade to that simply is better in all areas. You’d think one exists, but I’ve yet to find one that follows the Harman curve very well, most have flat response in the bass. My preference is a bit lower in the bass than Harman’s, so they don’t need to be boosted as much, but a flat response is for sure not for me.
EDIT: Or it may be what
@GGroch said and the level in the bass isn’t what makes it too much, but the distortion. Not sure.
