Philips CD204 (Review)
snowbl1nd
Hello Everyone,
Let me introduce a little "overview" and measurements of the Philips CD204 compact disc player.
The CD204 is a second-generation Philips CD-player from 1984. Its circuit design is identical to the older Philips models and uses a Philips CDM-1 transport made of diecast zinc/aluminum. The entire enclosure (and internal chassis) is made of metal, but with a plastic front panel. 7 kg weight. RCA cable is soldered inside like the power cord. Unfortunately, there is no digital output.
The digital-to-analog converter based on two 14-bit TDA1540 chips. It is claimed that oversampling compensates for the loss of bits.
The player arrived non-functional. After some re-soldering, it worked. Just in case, I replaced the infamous blue Philips axial capacitors and the transistors on the tray control board. I'm not sure the player is working properly, but I have no complaints. It struggles with reading a test disc, as it behaves randomly after track 30, but if you play tracks sequentially without switching, everything is perfect.
The no-name CD-R I accidentally bought was showing mess on some tracks, but thanks to NTTY and Vintage02 I was able to take measurements from the "factory" disc.
My setup: Philips CD204 (Test CD) --> MiniDSP PocketADC (coax) --> DIR9001 (i2s) --> SA9227 (usb) --> Win11 --> REW
Measurements (Analog out, stock cable)
999.91Hz sine @0dBFS (without and with dither)
0dbfs / -1dbfs / -3dbfs / -6dbfs (without dither)
L Sine_0db_NoDither.jpg L Sine_-1db_NoDither.jpg L Sine_-3db_NoDither.jpg L Sine_-6db_NoDither.jpg
0dbfs (L+R) / -1dbfs / -3dbfs (L+R) / -6dbfs (with shape dither)
L Sine_0db_wDither.jpg R Sine_0db_wDither.jpg L Sine_-1db_wDither.jpg L Sine_-3db_wDither.jpg R Sine_-3db_wDither.jpg L Sine_-6db_wDither.jpg
Multitone
IMD AES Analog
18kHz and 20kHz, -3.02dB
Pitch error and jitter test
Oversampling filter response test
oversampling_filtering.jpg R WhiteNoise.jpg L WhiteNoise.wav.jpg L Triple_9-19-20kHz.jpg
3DC measurement
Unfortunately, I don't know what's going on here.
Thank you for your attention!
3DC measurement
I forgot that high-frequency noise can affect the results. Unfortunately, my ADC doesn't support 44.1kHz, so I repeated the test at 48kHz.
Recycle it responsibly, don't put it in landfill.
Or sell it on this forum to a collector for £8000.
What are the reasons to scrap one of the best drives that has been in service for over 40 years?
No digital out.
