Philharmonic Ceramic Mini (review and measurements by Erin)
sweetchaos
The Curator
BC, Canada
Video review:
Spinorama:
Review: https://www.erinsaudiocorner.com/loudspeakers/philharmonic_ceramic_mini/
Mfg site: https://philharmonicaudio.com/Ceramic-Mini.html
Discuss!
To use a rounded shape makes no sense. Speakers are *not* aerodynamic devices, or build as a plaything for a kindergarten. It is just kitschy, especially now that everbody does it.
The technical merits originate in the SB drivers. And so they are as limited. Not bad at all, only a bit less perfect.
The layout doesn't convince me at all. No waveguide, the crossover frequency way too high. And as I cannot imagine how P/A solved the problem of port noise (chuffing etc) I give them the benfit of doubt.
Finally, because Erin mentions it, the intermodulation (thank's for doing the measurement!) is expected, but still, it is too high for a seriously 'natural' sound with ceramic :rolleyes:
2 kHz is "way too high" for a 5" driver? People like curved cabinets. Any science on what IM distortion level is needed for a "seriously natural' sound?
It's entirely up to him, but it would be fascinating if @Dennis Murphy would drop in to give an overview of the design decisions he made. I'm pretty sure he's posted before that he considers the tradeoff between uniform directivity and wide directivity but weights wide directivity more.
I think the rounded cabinet shape does affect the smoothness of far-off axis response at lower frequencies that begin to bend around the box, but others would know more about this than I.
Waiting for the full range version
Im still dont know why companies still making no hifi speakers
20hz to 20khz
There is a little more round-over on the curved cabinet than we would have on a rectangular one, but clearly not enough to eliminate the mid-treble diffraction. A curved cabinet has some theoretical advantages (rigidity, internal standing waves), but I've never heard any difference. With my speakers at least, it's purely a matter of aesthetics. Wave guides definitely can make life easier for a speaker designer. Fairly narrow-dispersion ones pretty much eliminate edge diffraction and may allow a lower crossover point. And that type will improve directivity, at the expense of broad radiation. Wider radiation guides, such as used by Revel, won't do much to reduce diffraction, but can produce more even directivity. But almost by definition, a guide will reduce the dispersion of the tweeter, and many guides color the sound. My experience is that wave guides are difficult to implement optimally, and even where successful a speaker with broader dispersion but less even directivity may sound better to some people on some music. My opinion, and it's only an opinion, is that wave guides are not needed on 3-way designs if the right drivers and crossover points are chosen. Two-ways are a tougher call. I've chosen to use as low a crossover point as possible and smaller woofers and not risk the downsides of many wave guides. But in the end it's what comes out of the speaker that counts. Plop the Ceramic Mini's next to, say, a Revel M16 and see what you think. I'm guessing opinions will be divided.
No, my bad. It is o/k-ish. Especially as you (?) managed the suck-out vertically pretty well. But still, a waveguide please ;)
People eat french fries. No good reason to feed your children with such diet on a daily basis.
Hopefully I got your attention. I personally think that IM is a new frontier. My threshold for detecting IM is about 0,3% in the lower mids in a quite analytical situation. I would (not so) happily allow 1% as a realistic limit. Which defines the max level a speaker shall reproduce. Given that, the 'Ceramic' might be useful up to 85dB single @ 1m. Not bad at all! But there's a viable alternative : same internal volume sealed, 7" bass up to 300Hz, 3" mid plus tweeter. A *real* three-way. Behold, though, I patented it (pending)!
Well done, Dennis. But not as innovative as the curved shape and nice paint job suggest, sorry :)
edt: it doesn't make sense to measure IM of a reflexed speaker (ported) when driving it with sub-tuning frequencies. I think Erin does it to some degree with the 20..20k piece.
Mixed reaction to all of this. Are you referring to a suck-out in the mid-treble diffraction region or at the crossover frequency? If the latter, a properly designed 4th order acoustic crossover should generate a deep dip if you go high enough to throw the tweeter and woofers out of phase, since they should be in phase on the design axis. I've already posted my thoughts about wave guides, and I don't intend to use them. A surfeit of curved cabinets is considerably less dangerous than a ton of French Fries. I'll wait until I see a properly designed ABX test for IM distortion audibility before I start worrying about levels exceeding 1% above 85 dB. I think we're in agreement on 3-ways vs. 2-ways. If I could design a decent 3-way in the Ceramic's cabinet and bring it in for $850/pair, I would. Cheers
The science behind this bold statement?
I'll wait until I see a properly designed ABX test for IM distortion audibility ...
I'm a subjectivist. I investigate my own hearing so far, and what comes out is what is. The quality of the stereo is about me, not others. I don't have to proove my findings. I'm just advocating this nowadays quie accessible approach, as we have lots of handy tools in nearly every household.
Basically I was trying to be funny, because I made a wrong statement on your cross-over choice. My apologies. Again, well done with good drivers. I like my KEF R3s :)
This looks good. I was intrigued by these speakers and almost tried to buy a previous incarnation of these.
I feel like the tweeter could be padded down another 1-2 dB to make it a little darker sounding speaker and remove the very slight sibilance Erin mentioned. I wonder if Dennis tried this and it sounded too laid back.
The BBC dip looks pretty well executed. Interesting from Erin that this speaker may sound best if you sit above the plane of the tweeter and leave them pointed straight into the room with no toe in.
These components at this price is compelling. The parts are better than the Revel m105 for much less money. Internet only Ascend Acoustics will only sell you the soft dome tweeter Sierra-1 for a slightly higher price.
Funny.
Didn't even take a full page before somebody started commenting about waveguides and complaining about minutia measurements... And comparisons to KEF and Revel were made.
:rolleyes:
Par for the course.
@Dennis Murphy .... Congrats on another winning design! Not that there should be much doubt. ;) Once again, at your price point and SQ goals, very little can stand in comparison.
Cheers!
Funny.
:rolleyes:
Par for the course.
Cheers!
That was all predicted on the other site iirc... And congrats Dennis , once again you give us better results value wise ....
