- Joined
- Jun 5, 2020
- Messages
- 4,800
- Likes
- 3,744
The 1430 cu ft room is definitely helping. I use Audyssey, however it doesn't alter the extension of a speaker. It detects the F3 and does not create filters below that point.Is that after EQ? If not, then I think you may have an atypical room. When I tested them in my room, I was only getting 34-36Hz extension. My 160lb towers only get 27-30Hz in here. Website lists 33Hz in room extension, which was close to what I experienced. Never tried the BMR(though I plan to some day), so I can't speak to that. They're much larger though, so I'd assume they could dig a bit deeper(maybe 5Hz or so?).
For this graph, I was testing crossover settings to see how much relief it offers the speakers. Black line is speakers set to "Large", aka bass management is off. Then, it's 40 Hz, 60 Hz, and 80 Hz crossover settings, measured with the subs on in the AVR but physically turned off. @EEG this is just bass management done with an AVR – the subwoofer used doesn't matter. @Beave
If you look close you can spot the room gain
The null at 95 Hz is due to an axial (length) mode
