R Swerdlow
- Joined
- Jun 9, 2020
- Messages
- 74
- Likes
- 114
The Meniscus Audio Bare Bones Kit does not include port tubes at all. The Full Kit adds a number of useful parts to those of the Bare Bones Kit, including two Precision Ports with wide flares on both inner and outer ends. In my opinion, these flared ports do improve the sound quality when compared to non-flared port tubes. They're well worth the added price of the Full Kit.What kind of ports are included in the Optional Kit from meniscus audio? The flared ones or simple tubes?
The proper balance between the woofer & mid-range driver for an 8" wide front baffle has been built into the crossover design. This is sometimes called baffle step compensation (BSC). If you change the front baffle width, it would require a redesigned crossover to provide the correct level of BSC. IMO, it would be best not to change that.Why the baffle width is not negotiable? I'm asking because there is surely somewhere a picture with a much wider black BMR. I cannot find it right now. Also ,in the early specs of the BMR i found a 9" value for the width of the cabinet.
As you estimate the internal volume of the bass chamber, don't include the volume of the damping material. It's porous and is still part of the internal volume that the bass driver "sees".The active volume of the speaker. Correct me if I'm wrong. Cabinet volume minus small BMR driver box ,minus the volume dislocated by the other two drivers( the Scanspeak in particular) , minus the port tube volume(?) , minus the bracing wood piece , minus some dumping thickness(?)
The Meniscus Audio Full Kit also includes the appropriate amounts & types of damping materials – another reason why I like the Full Kit. Dennis Murphy says the type & amount of damping material for the mid-range chamber is critical to the mid-range sound quality of this speaker.
