You see this a lot on rear ported speakers in the soundstage measurements. Below 80hz or so it seems best to take it with a grain of salt.
@Dennis Murphy Could you, perhaps share also off-axis -15 -30 -45 measurements of the BMR that you are using? I spent a few years building active speakers with 4.5 inch BMRs as a fullrange, crossed over to small subbass section, and i must say, that there is indeed something special about their sound, also thanks to the DML/BMR principle they can take unbelievable beating given their size, but after a lot of extatic overreactions, and long time experimentations i have found out, that their biggest advantage is also their biggest weakness- you almost cannot equalise BMR driver to have reasonable radiation pattern- their response is changing wildly with each small turn from the axis. That, and also the BMR specific distortion, which is unrelated to the current SPL makes them finally disqualified from my future projects, and that is in my opinion the reason why these interesting drivers would never be widely used in high end audio.
I've given the Purifi woof every opportunity to prove itself in the BMR, including running it with two of the Purifi passive radiators, and I finally gave up. It's a very specialized animal. It performs about as well as the Scan 8545 in a smaller cabinet, which makes it a prime candidate for a premium 2-way in a cabinet of .5 cu ft or less. But even in that application the port has to be too long to fit without bending it and introducing even more port noise. The passive radiators solve that problem, but in a larger cabinet the bass response falls off below 100 Hz and the midbass is thin. Given how much more expensive the woofer + PR's are compared with the Scan, it doesn't make sense to reduce the volume of the BMR cabinet to achieve essentially the same results. Also, I have been extremely impressed with the performance of the SB Acoustics ceramic woofers, and have decided to incorporate the 5", 6", and probably 8" in a series of speakers manufactured in China and sold here starting in the Fall. The first will be a mini monitor with an excellent AMT tweet for nearfield listening and HT surround. The second will be the BMR with the 6" ceramic, and the third, not yet designed or proven, could be a tower with the 8" ceramic, two BMR mids, and the RAAL tweet. That way, each speaker will have specialized applications appropriate for their asking price, and not just a marginal improvement at greatly added cost. The new BMR shouldn't be regarded as an improvement over the Scan version currently available as a kit. It will have somewhat higher sensitivity and the bass extension will be the same at normal output levels. But the Scan still has more power handling for rockers. The reason for switching to the 6" ceramic is to reduce cost enough to keep the regular BMR relatively affordable. Given the trade war, however, the price will be enough higher than the kit to make that an attracitive option for DIY'ers. The Chinese have become more flexible of late when it comes to cabinet quality and variety, and the new BMR's will have a very high-end veneer finish and eventually a wide range of finish choices.
For those who can measure impedance of their BMR kits, here are two impedance vs. frequency graphs. For bass performance, the important feature to look for is the impedance saddle at ~33 Hz between the two impedance peaks.The best and easiest way to check for bass tuning is with an impedance sweep. Do you have the ability to measure impedance? If so, the two impedance peaks forming the saddle should be absolutely symmetrical, and the saddle should be centered on about 33 Hz.
Swerdlow has already illustrated the off-axis performance of the BMR, and you can see complete 3rd party Sinorama measurements here:
https://www.audioholics.com/bookshelf-speaker-reviews/bmr-philharmonitor-1/conclusion
I can only conclude that you were using a different driver (I'm not familiar with any BMR larger than the 3" I used), or somehow measuring differently. I also haven't encountered any distortion issues. The NRC didn't run into any even at 90 dB at 2 meters. The RAAL ribbon does start to huff and puff at the bottom of its range when driven that hard, but not the midrange.
I'll check them out. It's possible the bending principle doesn't work as well on larger diaphragms.Yes, i was using BMR85DDXE N4R from Cotswold Sounds, from UK. Perhaps you are also familiar with their products?
MAybe the smaller driver that you are using behaves better, i am just waiting till someone in Europe will sell his used Philharmonitors, so i can test them myself![]()
Is Salk just trying to make a quick profit?
Now that I think about it, it probably is probably used as a credit to upgrade and they gave the owner credit based on the current listing (even if the cabinet is not as good as Salk’s). So, they are helping out that customer by giving them a larger credit and thus likely purchasing a more expensive speaker from Salk. Still, paying more for a used model than what it used to cost new ain’t great.I think it's more that Dennis was making basically zero profit. His margins were famously thin.
From measurements they are pretty flat from 0 to at like 45 degree, I guess toe in or not toe in are both okay? What do most people do wjen their speaker got wide directivity?Can anyone tell me (because finding this specifically via google is turning out to be a chore):
What is the designed listening axis (vertical and horizontal) of this speaker?
I assume 0° horizontal and "tweeter" level veritically. But I would like to verify this for sure.
TIA
I listen to my BMR's with no toe-in. If you look at the measurements Swerdlow posted, you'll see that there's a little dip at 3 kHz that goes away fairly quickly off axis. So the smoothest early arrival response will actually be off axis. Does it really make any doo da difference? Probably not, but at least you can be confident that you're not missing anything if you or your SO wants the speakers pointed straight ahead for aesthetic reasons.From measurements they are pretty flat from 0 to at like 45 degree, I guess toe in or not toe in are both okay? What do most people do wjen their speaker got wide directivity?
Yah it's zero degrees vertically. There was also no need to toe them in. When I had them, they had the most stable image no matter where I was. Even far off axis in the kitchen, they had a phantom center. I think I remember reading somewhere.in the AVS forum, Dennis recommending them to be used with no toe in? But that was a long time ago, so take it with a grain of salt.Can anyone tell me (because finding this specifically via google is turning out to be a chore):
TIA
I listened, two years ago, to the BMR speakers that made the BMR Road Trip. From one photo, it looks like they were arranged with no toe in. Dennis drove them to my nearby house and was present as we listened. So the speakers probably had no toe-in. I don't recall fussing about their arrangement.Can anyone tell me (because finding this specifically via google is turning out to be a chore):
Nice, I am really looking into the individual driver performance, specially ribbon tweeter because there is no measurement of it.Thanks for the info, guys.
I am asking because I plan to measure these speakers and, while I assume on-axis horizontally and vertically aligned with the tweeter is the ideal reference plane, I want to make sure what the reference axes are before I go off half-cocked. Looks like my assumption is correct.
I've already begun my listening evaluation (something I always do before measuring or looking at measurements so I don't bias my opinion) and I started with the above orientation. I also moved them to forward-firing just to see how the angle effects the result.
What an awesome review!
https://www.erinsaudiocorner.com/loudspeakers/philharmonic_bmr/
Best,
Anand.
