GelbeMusik
- Joined
- Apr 19, 2020
- Messages
- 445
- Likes
- 292
... figure out a way to make it work, be it with a port, transmission line, or ...
Since I use digital room correction, I don't care about bass alignment too much. Reflex always wins. Only after I correct in-room response. Tuning is all the same every time: just about 35 to 45 Hertz for reasons You know all to well.
I was referring to "chuffing" of the port once the excursion with the Purify multiplies.
You were clearly promoting the Tymphany TC9FD18-08 as a step up from the BMR, and I was pointing out that you might wish to do some cross checking on sensitivity. Also, can you point me to documentation for your claim that the little Tymphany has "drastically less distortion"?
Nope. It is DIY. The TC was advertised by so many, You couldn't have missed it. Regarding sensitivity I could tell a lot. Only that most of the readers here wouldn't be able to follow it. Let's try: The SB17NAC35-4 (4Ohms) would go with the TC. With 90dB@2,83V on infinite baffle, corrected for baffle step only 84 would be left. The TC would have a) bandpass gain, b) gain from baffle directivity. And it is smooth as moonlight, so no delicate corrections, hence not much of reserve needed. The TC with bare 84,5dB fits easily. Even more so with the 8-Ohm variant of the SB. You know that.
You have many followers here. I don't want to learn more.
Regarding dispersion BMR wins, also on power handling/compression (32mm voice coil in BMR vs 20mm in TC9). Given that crossover frequency went up tp 900Hz, it may not be an issue, but pairing tc9 with RAAL 64-10 at 3.5kHz-4kHz might.
Nope. No considerably better disperion than a larger wideband TV speaker, the TC9. Available volume is limited by distortion / intermodulation, not by power. Regarding XO: with waveguide I dare to use even 25mm tweeters from 1kHz on. Only lately I explored "wide dispersion". 7" bass/mid and a naked 1" tweet on top--again from 1kHz on. No distortion, no burnt voice coil with elevated levels.
